Oil Temperature Sensor Location - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 09:02 AM
Is There A Good Reason Why An Oil Temperature Sensor Couldn't Be Mounted In The Oil Pan Drain Plug Besides The Obvious - - - Disconnecting The Sensor Wire When Changing The Oil??? The pan is an extra capacity unit with the plug location on the side.
Old 05-07-2011, 09:44 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would be afraid it could come apart (dumping the oil out) if somthing hit it
i don't think your pans' plug even has the same type of threads as the sending unit
Old 05-07-2011, 04:59 PM
Into the oil pan drain is the typical place to install the sensor to get a bulk oil temp reading. The only other choice is to drop the pan to weld in a bung, which is a lot of work. There really isn't anyplace else such as an oil passage where these things can be screwed in without the sensor's presence interfering with the oil flow inside the engine. If the engine has an oil cooler a line can be tee'd using one side for the sensor to measure the temp of the passing oil. Or you cold put on a cooler adapter but just plumb a loop through a tee fitting to accomplish the same thing.
Bogie
Old 05-08-2011, 09:11 AM
So Far, I'm Not Hearing Any Real Down Side For Mounting The Temp Sensor Into The Drain Plug. The Plug Is Out Of The Way (on The Side) And Routing The Wire Would Be Easy. The Only Negative I Can See Is That I'll Lose The Magnetic Insert In The Plug.
Thanks For The Input . . .
Temperature Sensor Posts Sleezie Engine 8 03-05-2011 09:30 PM
temperature sensor location hudley Engine 1 12-20-2006 08:33 PM
BBC Location of Temperature Sensor unstable Engine 5 09-16-2003 12:45 PM
tcoolant temperature sensor removal Glenn56 Engine 1 07-25-2003 09:35 AM
77 chevy engine temperature sensor location??? 77chevy400 Engine 4 07-09-2003 02:51 AM
