Which oil viscosity? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 10:04 AM
Madmax305's Avatar
Hey guys I need some suggestions about which oil viscosity is best for my SBC 350. It has a hyd flat tappet comp 270 magnum cam. I will be using VALVOLINE VR-1 RACING MOTOR OIL because of the extra additives for flat tappet cams. Should I use 10w-30 or 20w-50 weight? I live in Southern California so the temps are pretty warm here, even during the winter.
Old 02-18-2011, 02:27 PM
BigRoy1978's Avatar
The VR-1 is a rip off, did a lot of reaserch in it, and it only has a tiny bit more additives. Not worth the price for what they are sayting they are selling. They do make a VR-1 thats an actual race oil, its in a black bottle and has to be special ordered. Completely different blend than their silver bottle VR-1, even smells different! And is cheaper, about 4 bucks a quart compared to 7-9 a quart for the silver bottle. But, is not street legal since it has enough zinc to clog your cat. converters.
If your worried about using something for better wear protection, try diesel engine oil. Rotella, Mystic...stuff like that. Hot Rod tested lots of oils, and the diesel oils came out near the top...even against great "race" oils.
I use mystic, blended synthetic, in my street cars. Works great, usually 10w30.
For my racecar I run Brad Penn 20w 50, but would rather use 10w30.
Old 02-18-2011, 03:59 PM
Tell us about the build, a Magnum 270 cam is very good. Few cams that stood the test of time, that got it right the first time.
10w40 if the temp stays about 35-40. The 5w30 in the winter.
small tip,
With 6 quart pans after barak in , add a quart of mobil 1 synthetic , 5 of the petro oil. The Mobil 1 synthetic is good stuff, after trying many different cutter oils on my lathe. Metal pressing to metal with tons of pressure, mobil 1 gets it done. The synthetic mixes well with into the other similar viscocities.
Old 02-18-2011, 04:32 PM
Why is VR-1 (silver bottle) a rip off?
Valvoline conventional oil has 0.083/0.076 Z/P.
Valvoline VR-1 (silver bottle) has 0.13/0.12 Z/P, and enough detergent for street use.
Valvoline Not Street Legal (black bottle) has 0.14/0.13 Z/P and not enough detergents for street use, according to Valvoline.
Do you have different numbers? If so, where did you obtain them?
I fail to see where there is a rip off.
Old 02-18-2011, 05:47 PM
BigRoy1978's Avatar
Cause they put VR1 RACING OIL all big on the bottle, put all this advertising and charge stupid money for it. The last bottle I bought was like $7.50 a quart for this "racing oil".
Their black bottle, which has more additive and such only sells for $4.50 a bottle and is actual racing oil.
Just "good" marketing by valvoline i guess.
Short guide on tips and viscosity. cjperotti Body - Exterior 15 06-02-2009 05:17 PM
Richmond 6 speed gear oil viscosity... AllenKarber Transmission - Rearend 0 05-24-2008 10:22 PM
Paint Viscosity Follow Up x711 Body - Exterior 14 12-01-2005 10:14 PM
HVLP Spray guns and paint viscosity: x711 Body - Exterior 21 11-15-2005 08:49 PM
Oil Viscosity And Bearing Clearance Relationships HJCHEVY400 Engine 9 04-16-2004 12:29 AM
