Oil/Water Seperators on Air Piping - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2009, 08:28 PM
I am going to be installing an IR air dryer along with 7.5HP 80 Gallon IR air compressor that I just picked up.
Do I need to install Oil / Water Separators in between the air compressor and the air dryer and between the air dryer and the wall mounted separator / regulator?
IR recommends doing so in their product literature, but is it really necessary? Doesn't the air dryer function like an Oil / Water Separator in itself?
Old 10-28-2009, 09:14 PM
Depends on what you intend to do with this thing, that's a lot of compressor. If you are talking about an average shop then probably not but if it is to be used in a multi-employee facility that will be working constantly for 8 hr days or more then it would probably be a good idea.
If you are talking about the refrigerated drier I think you are along with that compressor you are going to have a very nice set-up there!
Old 10-30-2009, 08:49 PM
Do you have some drawings, and how long the pipe is beween the dryer and the compressor. Also the type of pipe and what size.
Air compressors make a lot of hot air that needs a good run of piping to cool it.
Heres a set up without an air dryer that works, anyway.
http://www.1969supersport.com/draw1.html
Rob
Old 11-01-2009, 02:30 PM
water trap
Yes, install a water trap in the system even if you don't intend to paint, you still need to keep moisture out of your air tools.
I was a Beemer tech for 33 years, I had a water trap AND auto oiler mounted on the end of my tool box into which I plugged a shop air hose.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
