Oilcapacity mopar 360 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2005, 08:34 AM
New Member
I'm trying to fit in an 360/727 engine in my Dart (original /6) - in the /6 k-member. In order to make the engine fit, I need to modify oilpan and move the oilpump tube and the "oilpan belly" to the center of the engine. This modifications is affecting the total oil capacity and interfere with the dipstick-guide.
Question: what is determining the correct oil-volume in an engine, and how can I figure out whats proper volume in my engine?
Pettersen
Old 06-21-2005, 10:14 AM
GoneNova/406's Avatar
i watched a horse power t.v. show called the king fish where they took a 1967 baracuda i think was the yr. and took out the 440 that was in it and replaced it with a new 360 from jegs and changed the K member back to the original one.they got the new K member from a mopar junk yard specifically for the car in mississippi or alabama.i don't remember the name of it but if you go to the horse power t.v. site and look or email them i'm sure they will give you that info..that yard had nothing but mopar stuff and they were very knowledgeable about the subject and ship anywhere in the u.s..you should get what you need to use a regular 4 qt. pan.if not you may have to go to a dual remote filter set-up with qt. can filters for the extra oil capacity.good luck
318 build up(or 360) JeepStang94 Engine 5 02-11-2005 04:37 PM
Motor Mount Know-How needed antirawker Engine 7 11-30-2004 01:23 PM
360 mopar swap street rodder 1937 Engine 1 11-02-2004 08:49 PM
Swapping 273(or 318) to a 340/360 in Mopar A-body Gilligan Engine 7 09-18-2004 09:42 AM
Mopar 360 ID chris72j4 Engine 1 05-20-2003 06:25 PM
