Oiling Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2010, 11:39 AM
Oiling Question
Ok, so im getting ready to put my sbc together and have a question. I like the old style valve covers that say Chevrolet on them but hot no oil hole. But i dont like the intakes with the filler tube in the front. Is there a way to get the best of both worlds. Can i put a fill hole in the valve cover. Anyone done this before with success? The covers are flat without the ribs, but have the raised lettering. Maybe i just need to pick one or the other.
Old 09-25-2010, 01:54 PM
SSedan64's Avatar
Originally Posted by eheine20
Ok, so im getting ready to put my sbc together and have a question. I like the old style valve covers that say Chevrolet on them but hot no oil hole. But i don't like the intakes with the filler tube in the front. Is there a way to get the best of both worlds. Can i put a fill hole in the valve cover. Anyone done this before with success? The covers are flat without the ribs, but have the raised lettering. Maybe i just need to pick one or the other.
What type Crankcase venting does this Engine have? PCV? Down draft tube system?
If the fill neck on Intake has a Breather cap the new fill hole in Valve cover will need one if you change Intakes. You could add a PCV hole in one cover & fill/vent hole in the other. A Hole saw for drill works perfect, then deburr the hole & add Grommet/Cap/Breather
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Fuel System question Ratoflic Engine 6 01-23-2010 12:10 PM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
