Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ok, a few more stupid questions about this top.
  #38 (permalink)
Old 06-14-2012, 11:18 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Duh, I just went back and saw your post on the stapler and it seems this will do the job. Are the 3/8" staples going to do the job?
Use the correct length staples for the job. If what you're stapling into is deep enough to hold that length staple, you are golden. If not, you may need some 5/16" or 1/4" staples. When you attach the wire-on to the rear bow you might need 1/2" staples due to the thickness of the wire-on.
