Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ok, a few more stupid questions about this top.
  #156 (permalink)
Old 08-25-2012, 08:17 PM
delkra's Avatar
delkra delkra is offline
Originally Posted by DanTwoLakes View Post
You don't have the pads permanently installed either, do you?
I'll say it again. You can play with this until you're blue in the face with your spring clamps, but the pads need to be installed properly, and permanently, the rear bow height needs to be set permanently along with the rear curtain, and the rear of the top needs to be attached solidly to the trim stick before you can fit the top on the frame properly.
The pads are permanently installed! The rear bow height is set, but a little too far forward (like we discussed earlier). The rear curtain is fully stapled (lots of staples) to the rear bow.
What you are seeing there is from when I was test fitting the pads - it was the only pic I had to show Gringo where the pads went to on the sides of the rear bow. I unfortunately didn't take pics of when I fully stapled the pads and clipped off the over-hang on both the front and rear bow. (No spring clamps! )
I have the rear trim stick completely stapled at this time - only the rear and front bows are un-stapled. I think it is working out, but I have to take some more pictures. I'll post them once I do. The only spring clamps left are holding the blankets to the outside of the car for protection of the paint!!!
Do I have to staple to the rear upper bow before I can staple the front bow? From my understanding I could get away with leaving the rear upper bow unstapled. I would want to leave it un-stapled over the rear bow ONLY until I can get the front bow situated and then I would staple the main top the rear bow as well.
