Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ok, a few more stupid questions about this top.
  #159 (permalink)
Old 09-03-2012, 01:06 PM
MARTINSR MARTINSR is offline
Thanks so much guys for the info and push to cut that top at the bow and remove the wrinkles. It worked very well and actually pretty easy.
I then did the other side that was a little harder. I lifted the top up off the windshield to loosen it up and found that probably wasn't the way to go as I had to remove the staple I put in and move it a little and re-staple it. I then using a nice sharp razor cut away the excess and under lying material.
The wire-on will cover it easily and it is going well. I tightened up a few more wrinkles and it is looking VERY good.
Thanks again for all your help guys!
