Ok, a few more stupid questions about this top.
33K views 174 replies 8 participants last post by  John long
I see in the GM assembly manual these things called "fillers". Over at the Goodguys I was able to see down into this area on a car and it looked like there were some dense foam pads at this spot. Is that all these "Filler" amount to, sort of a pad where the tack ("trim") strip screws to the body?
Next, it shows this measurement for the rear bow. It's extremely clear, 17 and 5/8 inches from the inside of the rolled edge on the rear bow to the center of the next bow. This is perfectly clear, make a stick that goes here to hold it and done deal, put the rear curtain in. That's how I see it at least.
But then they give this very elaborate directions for making a stick that would go there and it's adjustable! Why the heck would it need to be adjustable if this measurement is so defined and clear?
Thanks, Brian
See less See more
3
#2 ·
Oh yeah, another question. This one on the stapler. I went to the hardware store and found that they don't have any pneumatic staplers that use the staple like I found in the top when I tore it down. They were the normal 1/2" wide or so quarter inch deep staple. I forget the terminology but they were half as wide.
Can you literally hand staple these tops? I have a high quality hand stapler but haven't tried any tests, is there hope to just hand staple it?
How about stainless staples so they don't rust, is there such a thing?
#4 · (Edited)
Yes, there are stainless steel staples available for most staplers. Hand stapling would be difficult, but not impossible, they used to put them on with tacks and a tack hammer. I generally use my BEA gun (the blue one on the right) with stainless staples for tops, but the Central Pneumatic 96359 shoots Arrow T-50 staples, and would work also. There are stainless staples for it also. You could also buy a DuoFast electric stapler that shoots T-50 staples.
Thanks, Brian
I don't know what the fillers are for, none of the tops I've done had anything like that. That 17 5/8" measurement baffles me, unless that has something to do with the pads. The bow height is the important measurement. Get that right and you will be fine.
#6 ·
Where did you get the stainless staples?
I'm thinking the fillers are a little pad of some sort that get lost after the first top is replaced. On the measurement stick, how in the heck do you set the bow height? This measurement stick is all I have found to measure where that rear bow goes. But now that I think about it, it is measuring it to the top it's self. With the adjustments I have done to the top at the windows (along with the windows) THAT has changed the location of that rear bow to the body. So if that rear bow height is so critical, how the heck do I set it?
#8 ·
This sort of explains it, if you didn't get the measurements from the old top, then you use this 17 5/8" distance. But again, this is the rear bow to the next bow not the bow "height". Where do you measure the bow "height" from the rear body edge?
This is the step 16 mentioned.
#10 ·
top
The little pads have a couple of purposes. They go on metal first over the holes in the body. They can be thick tape, rubber, or a clump of body sealer. They are to seal bolts so they don't leak into trunk and I think they space top out a bit so water doesn't sit there and can drain down to drain tube. As for stainless staples, I don't use them. They are out of the weather and usually last as long as the top. You should get 1/4 and 3/8 staples, gonna need some longer ones in some areas. As for that measuring stick, that is when you put the pads on after you set rear bow height. Harbor freight has a stapler. I bought one to use in shop for general use and seems to work fine. What is this car? I can look up rear bow setting for you. As for an adjustable stick, I'm guessing that is so you can use it for different tops?
#11 ·
tops
Just another thought. Have you had body off frame, or had top mechanism out of body? Do your doors and windows line up good? Are body mounts good? Now is the time to check all this stuff. Put top in closed position and make sure weather seals fit all windows etc. If not adjust your mechanisms to fit. More fun stuff to think about. Just saying.
#12 ·
It's a 1965 Buick Skylark and yes the top was restored and it has been all lined up with the windows and rubbers (PITA!).
What you are saying all makes sense, thanks. On the "fillers" some rubber washers sound like a deal.
On the measurement being after the bow height has been set doesn't make any sense to me. The only think you could change with that measurement IS the rear bow height, or am I missing something? How do you "set" the rear bow height? If you held it there some how (being it falls freely) at a certain height, setting that 17 5/8" distance would require you to change that bows height, would it not?
#13 · (Edited)
The bow height is from the center of the edge of the chrome trim around the body opening for the top to the center of the rear bow. In your case it's 20 1/2". Yes, it falls backward to open the top, but the key is making the rear bow stay at that length when the top is up, not going down. You set it at the correct height with the top's frame completely up and latched. The pads are stapled to the rear bow as well, and they will hold it at that measurement. The opening in the top is centered on the rear bow, and then the wire on is put over the seam.
T-50 staples, plain or stainless are available at most home centers. I got those at Home Depot.
#14 ·
This is so odd that everywhere I have heard about this "bow height" yet in the GM manual they had a plan to confuse me as the bow height is measured from the other way!
Right off the bat I am befuddled as to what an inch one way or the other on this bow is going to do? The GM manual talks about it like it's a frigging piston ring gap or something. If that bow is up or down an inch what the hell would it matter? I could see with a fixed height window, or a glass window. But isn't the height of the window what the whole thing should be based on? What if the repro window isn't perfect, what if the repro top isn't perfect? I am lost on this whole thing being so critical when there is no mention of the top or rear window when this height is discussed. :confused:
#15 ·
I am dying to get home tonight and measure the bow height, thanks so much for putting up with me.
Now, what in the heck is the "wire" you mention?
#16 ·
The rear curtain goes on first, and the bow height has to be right before you staple the rear curtain to the rear bow. There is an opening in the top that gets stapled to the rear bow. If the bow height isn't right, the opening in the top won't line up with the center of the rear bow. There's a piece called wire-on that is stapled over the seam in the top at the rear bow. If the bow height is off by an inch in either direction, there's no way to cover the seam with the wire-on.
#17 ·
Ahhhh, I need to get my top out of the box and get a good look at it!
Thanks Dan, Brian
#18 ·
top
Does that second bow move? If not that should be your height. Some move back and forth a little. In my Atlas chart it shows 21 1/2 with a plus or minus of a 1/4" Find center of rear bow and center of chrome strip. Measure out 18" each way from center and mark. Measure at these points. Measure from center of tack strip to edge of chrome. I usually cut a couple of wood to hold in place. You will find out later as you start to put top on why you need rear set right. There a couple of funky slits in top that must end up over tack strip. Mark center of top and work out each way. Good luck.
#21 ·
****** said:
Dan are you using only center measurement? as opposed to the 18" from center. This could be the difference. My chart is old. It only goes to '73 but I've found it still works.
I have to tell you, I am going to walk out right now and see but if you go 18" from center in either direction it is probably going to lengthen that measurement because that rear body curves BIG Time. I'll go out and check, I just got home.
#22 ·
By the way Dan, I am a little confused in the description of how to measure that rear bow height. Center, edge, I don't understand.
Looking at the chart below, is it A, B, C, or D?
#23 ·
Well, just went out and my bow is 20 1/2" using the C version of measurement that you guys laid out for me. If it's B center to center it's 20 7/8". This is with the bow back from the second to the rear bow just as GM says at 17 5/8"
Anyway, I pulled out the goodies from the boxes I have been storing for 10-18 years. The pads look fine.
The windows, not so much. DAMN IT. One is in perfect condition but it has no side "skirts" on it. I guess it was a cheaper one. The window is sown in on this one.
The other one looks like much higher quality with a large skirt on the end, the plastic is bonded to the side some how on this one.
But alas, the damn window is all stained from being rolled up in storage, CRAP.
So tell me, is this top usable? It sure seems like it has shrunk. The following photos are with the front of the top clamped to the front bow as shown.
This is how wrinkled the top is, VERY bad, it has to be a lot shorter because of this. I left it sitting there to warm up tomorrow in the garage (it will be as hot as a two dollar pistol in there!). I am thinking it will flatten out a lot.
With just a gentle tug this is where the top looks like it ends up at the rear. This is just a gentle tug with the top all wrinkled as shown in the last photo. So I am thinking I can get another inch or two out of it easy.
What do you think, is this top savable? And where is a good place to buy a new rear window. Or top for that matter if I need one.
#24 ·
top
I'm curious as to were you got the 201/2 measurement. In the center? What is the measurement at 18' from center? That's a long time to stuffed in a box. I have stapled them to the top of my garage door and hung some weights to bottom and let them hang in the hot sun for a couple days. If rear window is scuffed or stained or mildewed you need to replace it. any auto trim shop should be able to order you what you need.
#25 ·
As I said in an earlier post the moulding has a big sweeping curve and I thought 18 inches from center would yield a far bigger number but it only added about a 1/4". So in the center measuring as in my drawing the C it's 20 1/2 in the very center of the bow vertically side to side on the car (as well as center horizontally) and then add a 1/4" if I moved that out 18" from the center.
This is all with a perfect 17 5/8" upper measurement exactly as the GM manual says.
I like your idea of hanging the top, I was thinking of that myself. I won't be able to until this weekend. But it will get darn hot in that garage tomorrow.
#26 ·
That is a center measurement. Does it make any sense to you that the bow would be 1" higher 18" away from the center?
