I see in the GM assembly manual these things called "fillers". Over at the Goodguys I was able to see down into this area on a car and it looked like there were some dense foam pads at this spot. Is that all these "Filler" amount to, sort of a pad where the tack ("trim") strip screws to the body?
Next, it shows this measurement for the rear bow. It's extremely clear, 17 and 5/8 inches from the inside of the rolled edge on the rear bow to the center of the next bow. This is perfectly clear, make a stick that goes here to hold it and done deal, put the rear curtain in. That's how I see it at least.
But then they give this very elaborate directions for making a stick that would go there and it's adjustable! Why the heck would it need to be adjustable if this measurement is so defined and clear?
Dan, this shows you where my brain is at, we had discussed this at length already and I forgot! Thanks for being so patient with me. Well, it looks like it is "C" and that is exactly where mine is at 20-1/2" WHOO HOOO, nothing more to think about. And that is with the top measurement exactly as GM says at 17-5/8" this is all looking good to me.
I will get out the old pads tonight and see where it all lays. But really if that bow is correct I could just staple and screw my new pads on, it's GOING to be right if I do that with the bow height correct won't it?
How about my issues with the two windows and the top shrinkage?
The top should be O.K., but the rear curtain is a question mark. I would hang both of them in the warm garage and see what happens. You can't go any further with the top until the new pads are in place and the rear curtain is installed correctly.
Brian: You are driving yourself crazy with this. Don't agonize so much over tiny little details. The original top was put in by somebody who could have cared less how it turned out.
Thanks Dan, and John. This is so far out of my world. The funny thing is I would cut the rear body and quarter and floor with rails out of a 2012 Mercedes and not break a sweat, this top has just kicked my butt, because it is something way out of my world.
But getting that top up there has demystifed it further, it is getting more and more in my world and I figure at the very least if this top gets screwed up I get another and do it again. But I have a feeling it will be just fine. On the rear curtain, something hit me, I can cut the "tails" what ever they are called off the one with the messed up window and put them on the other one, can't I? Or just get a new rear window, they don't cost that much. It just kills me because the one with the messed up window looks to be much better quality. You can see in that one photo that the window is terribly stained. I tried to see if it would clean but there is no hope.
I went out this morning before taking off for work and got the old top and pads out and I can put them up there just to make me feel better about the whole thing too. Funny thing is, I will bet this will be a lot better than it was and I drove it like that for years.
I think you will do just fine. Also I don't think any of your questions were stupid, that's how you learn stuff. Sometimes it's nice to pick someone's brain. If you have a shop nearby they could sew in a new plastic for you. Good luck and have fun. Later Jim
Well, I picked up a stapler and some stainless staples. They are 7/16" wide as opposed to the 1/2" wide ones that were in my old top. But in testing out the stapler in a number of different materials like the tack strip and some new rubber stuff that I put in the header bow it laughs at it running that staple in like it was butta. Is this all what you guys are using?
What length staples? I got 3/8" as that is what I see in the pads so it worked, but is that what I should be using?
I got out my BEA staple gun, (made in europe.) I went on line an only found suppliers that would only sell 50 K staples.min order. I took the gun and a duofast, and a bostitch into a place that does construction nail guns and he had all kinds of staples and in smaller quantity I have only installed 3 factory replacement tops and made one from scratch for My T bucket and one dune buggy. I Had Trim when I was an engineer at ford and the crew did about 50 per day. I watched a lot, speced tooling, etc. They used to set a spacer so the front bow was about a foot off the windshield header to tack it on, when they locked it down it was tight, perfect, they had the most problems getting the wrinkles out of the quarters, I used to have some polishing compound for flexible vinyl rear windows. paint polishing compound might work
Thanks for the tips. I had another guy tell me something similar with holding the front of the top up.
I didn't put much into it thinking the way the whole window is covered in the stain that it would probably ruin it anyway trying to polish it out. But I guess it can't hurt, I'll give it a try. Thanks again.
Use the correct length staples for the job. If what you're stapling into is deep enough to hold that length staple, you are golden. If not, you may need some 5/16" or 1/4" staples. When you attach the wire-on to the rear bow you might need 1/2" staples due to the thickness of the wire-on.
All of my suppliers (of upholstery supplies) sell any length staple for BEA guns in regular and stainless. I keep six or seven different lengths around at all times. Some have boxes as small as 1000 staples. They also sell Bostitch, Duo-Fast, Senco, and Fasco staples the same way. It's just like buying top and trim contact adhesive, or sew foam. You can't buy upholstery supplies at a Home Depot, you need to find an upholstery supply house.
I'm going to use my advice I tell people about car parts "Go ask the pro shops who they buy their parts from, it ain't Auto Zone". I'll find out where they get their stuff around here. I did get the staples I bought at Home Depot but these were the only Stainless ones they had.
Ok, how does this top look? I have it sitting in the sun on top of the wife's Family Truckster. It's looking a LOT better but still funky, is this something that will flatten out when it is stretched out on the top?
And how about this rear window difference, I am assuming I want one like on the right with the longer side curtains. What do you say?
The original top pads don't even come close to fitting back on the bows where they were. With it on the header as it was, the next bow lines up, the next one is a little off and by the time it gets back to the rear it is off by a few inches. But the measurements are all right on the money so it must be the pads that have shrunken?
This is the third bow and you can see light thru the hole where it was screwed to the bow, it is off about an inch.
This is the last bow, now It's just laying on the bows and I'm not stretching it but I would think it should reach.
Is it common to have to use this many staples? This is the rear pad where it meets the rear bow. I have to assume that it's normal being you staple the pads, then you staple the curtain, then you staple the top, it's pretty much normal?
In looking at the window that has the odd brown marks on it I am thinking it almost looks like it was tinted and the brown is failing somehow?
Yes, there are a lot of staples that go into the rear bow, from the pads to the rear curtain to the top to the wire-on.
The top will lose it's wrinkles when it is stretched, it may take a little longer in the end before 18 years of wrinkles come out, but they will come out eventually.
The rear curtain without the wings is what I'd use. There should be pads to provide the same support in the same places, and the wings are just another layer to deal with.
Ok, I put a few staples in one of the top pads, WHOOO HOOO! I am thinking these staples are running right thru that darn thing though. I remember being told to hold it off the material a little, I should just be experimenting I guess.
What is this extra material that came with the top?
First off you need to dial in your new stapler. Hold the trigger and you will see the blade that pushes in the staple protrudes past the nose of stapler. Hold down the trigger of stapler and use one of your small grinders and grind the blade of the stapler even with the nose piece and it will not cut thru the vinyl. the extra material goes around the front of the top to finish off the edge. Usually sewing around a piece of windlace cord. Can be stapled around a piece of rubber hose as in fuel line or vacuum hose.
After you get the plunger ground smooth you regulate the staple blow by adjusting the regulator to your compressor. To much pressure and it will cut the material. Too little and it will not drive it home.
While you can use windlace sponge rod to make the finished edge, the original top would have had extruded plastic header welt (also called header strip) sewn inside of the fabric. It is still available from ARO convertible tops: CLICK HERE
If you saved the old stuff from the original top, you can have the new fabric sewn to it. I think it looks way better than anything round to finish off the top in front.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
