ok, gave up my hopes for a rebuild, how does this sound - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2003, 08:58 PM
Muscle car fan
Money is tight, and so the rebuild has been put on hold, and cheap go fast parts are going to be used.
Here is the setup
74 Ford Gran Torino (approx 3700lbs with some gas)
351W with stock bottom end (approx 8:1 compression)
Edelbrock rpm air gap intake
Holley 670cfm Street Avenger
1" 4 hole carb spacer
removed egr
now what i'm planning on doing
stock heads milled 0.020 over fitted with comp cams valvetrain adjustment kit
summit cam (218/228 .471/.471 114lsa) 2,000 to 4,500
summit headers (1 5\8 in. pri, 3 in. coll)
Sound like an allright street motor?? anything i should add, or any suggestions?
i'm thinking about 275hp/350ft-lbs any other guesses?
'74 Gran Torino Project
351W, c6 trans, 9"
Old 12-05-2003, 11:29 PM
lluciano77's Avatar
I think you need more compression. It is better to go to the high side of the cam's recommended ratio. I would do a little work to the heads too. Unshroud the valves and open the exhaust ports a little. Other than that it sounds good.
Old 12-06-2003, 01:52 AM
RANGER_MIK's Avatar
drive it like ya stole it.
Hey !
What kind of exhaust?
Old 12-06-2003, 10:47 AM
Muscle car fan
Re: Hey !
2.5" or 3" dual with an h-pipe and some turbo mufflers (size depends on what i can find a local shop to do)
As i said that the rebuild will be on hold, how would you go about getting more compression lluciano?? or do you think i should try a smaller cam instead
I was thinking of steel shim head gaskets but not sure if the block is straight enough to use them. Are there any other good head gaskets that are real thin when compressed?
351W, c6 trans, 9"
Old 12-06-2003, 05:24 PM
badknuckles's Avatar
you talkin to me?
i would go with the smaller of the two you dont want your pipes too big cause the colder your exhaust is the slower it flows i would go 2.5
Old 12-06-2003, 05:56 PM
Muscle car fan
I'm pretty sure no shop around here has done any 3" pipes anyway, I just like the sound of 3 pipes over 2.5
351W, c6 trans, 9"
Old 12-06-2003, 06:30 PM
you talkin to me?
sounds nice and its a good idea if you have a serious motor (over 300hp) but it sounds like your going mild so its probably better to go 2.5
Old 12-06-2003, 07:05 PM
Muscle car fan
going mild for now anyway, with a rebuild shooting for 400hp out of my 351 (possibly 393 since there isn't much difference in cost)
but that would be a couple years away (and i'd rather do exhaust once instead of twice)
351W, c6 trans, 9"
Old 12-06-2003, 07:27 PM
lluciano77's Avatar
Re: Re: Hey !
Run 2.5 exhausts. 3s will be too big. Maybe mill a little more off the heads and match the intake angle to raise compression. If you don't do that, that cam is already pretty small so don't get a smaller one.
Don't get steel shims. Get the thinnest steel core laminate one you can get. It might be the .039".
Old 12-06-2003, 10:34 PM
Muscle car fan
Re: Re: Re: Hey !
how much would you suggest i mill?? wasn't wanting to take too much off so i wouldn't have to worry about piston to valve clearance
0.030" or more?
351W, c6 trans, 9"
Old 12-07-2003, 12:06 PM
Muscle car fan
well according to my haynes manual 0.040" is the max you can mill on sbf heads, 0.020" is the amount you can mill before you need to mill the intake manifold as well
If I were to match the intake to the heads when i get new heads would i have problems with everything matching up?? Will be getting afr's later on down the line, and don't want to have to get another intake (more $$ i have to save)
351W, c6 trans, 9"
