ok im stumped here... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 05:09 PM
83chevytruck's Avatar
i just installed a new engine in my 83 chevy truck. i replaced what i thought was a worn out original 305 with a 350 bored .60 over flat top pistons nice 496 cam and am very pleased with the power. here i was lookin at this supposed 305 on my engine stand and decided to run the casting numbers for gp's . i come up with either a 350 , 400, or a 327. from 70 - 80 model. casting numbers are 3970010, head numbers are 333882 supposed to be 1.94/ 1.50 350 heads. im kinda shocked that this is a 350 but if so i am pleased as now i can build another engine for a spare. i need a second opinion on these numbers, so if you know what i have here dont be shy drop me a post.
Old 04-24-2011, 05:22 PM
could be a 350 or 327 the same number on both blocks you will need to no what the numbers on the crank are to tell what the stroke is.
Old 04-24-2011, 05:37 PM
Odds are it is a 350.
Old 04-24-2011, 07:14 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Pull a cylinder head. 4.00 bore with a 3.48 stroke is a 350.
Old 04-24-2011, 07:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 010 block is a 4" nominal bore casting- like used on the 327, 302 and 350. The crank will decide the final displacement. 883 cast heads are dirt common smog era heads.
Help I'm Stumped grapro Engine 1 12-25-2008 12:45 PM
Still Stumped 10mikeymike Engine 13 09-10-2008 11:59 AM
Need FI help. I am stumped so far! Siggy_Freud Engine 17 01-28-2005 06:22 AM
OK I'm stumped Kurt Suspension - Brakes - Steering 16 01-21-2005 09:48 PM
still stumped tweaked Engine 7 03-18-2004 08:07 PM
