Ok next up----Which plug wires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2014, 07:11 PM
31ROC's Avatar
Decided on the MSD 8360 distributor, with external Blaster 2 coil. Now on to the plug wires...suggestions?
Old 01-26-2014, 07:42 PM
jokerZ71's Avatar
Wrench Turner
I love "Livewires" by Performance Distributors.They are a really good wire.Available in blue,yellow,purple,black,& red.They run about $120 a set.
Old 01-27-2014, 02:20 AM
I used to have Acell Wires... worst junk you could ever buy.. never buy them.
a friend whom I have a lot of respect for suggested I used Taylor wires, they cost about the same as a set of acell wires.. ($60-ish) and they've been on the car for 5 or 6 years now.. NEVER a lick of trouble from them... and they tolerate the heat of the headers very well (Something the acell wires couldn't do) that #5 cylinder was always a pain, even with a 'shorty' plug in there.. the taylors handle it just fine.
i bought the custom-fit ones (cut them to length, put the other end on yourself) so they may have been a little cheaper, I'm not sure.
Old 01-27-2014, 05:38 AM
malc's Avatar
Living At The Speed Of Life
MSD's 8.5mm Super Conductor wire set.
Old 01-27-2014, 06:55 AM
Irelands child's Avatar
Taylor's you can never go wrong with along with MSD's though not sure that 'universal' length wires are available to be cut for neatness. Accel products have become IMHO, a laugh and a good way to waste your hard earned cash.
Dave W
Irelands child
Old 01-27-2014, 08:30 AM
malc's Avatar
The MSD wires I linked need to be cut to length, I always buy those.
Also included in the set is a crimper, and you get to choose distributor terminals,
HEI or regular.
Old 01-27-2014, 09:17 AM
HEI or regular.
Thanks - I missed that word "universal' in the Summit write up
Irelands child
Old 01-27-2014, 09:20 AM
jokerZ71's Avatar
Wrench Turner
With the Livewires,there is no cutting/crimping.You choose your engine & either over/under valvecover installation.Each wire is the proper length & numbered for the correct cylinder it's installed to.
Old 01-27-2014, 10:16 AM
malc's Avatar
I can make them the length I need to make them leave the distributor cap like this...neat.
Oh yes, you also get the numbers to clip on the wires....
Old 01-27-2014, 10:46 AM
I've used those already cut to length wires but prefer to make them the length needed instead. Neatness DOES count. These aren't quite right as I moved them from a conventional small diameter MSD cap to the wide, late Ford style but that will be fixed when they get replaced in a couple years.
Unfortunately the Taylor's don't come with the numbers but they are a bit less expensive instead.
Dave W
Irelands child
Old 01-27-2014, 02:01 PM
vinniekq2's Avatar
I like Aurora wires.
for standard order sbc dont run 5&7 parallel
Old 01-28-2014, 02:05 PM
mine run paralell, but they aren't right next to each other either.
Old 01-28-2014, 06:48 PM
Wiki Edits: 31
I'm going to third the suggestion to use Taylor wires.. They are reasonably inexpensive but are great IMO.. I had a wire laying on the header ( cheap stainless shorty's ) of my '95 K1500 and it did not burn before I cought it
Old 01-29-2014, 06:58 AM
31ROC's Avatar
Thanks everyone for the ideas...going with Taylor's universal Firepowers.
Old 01-29-2014, 08:37 AM
The mobile view is crap
I've looked at these wires before and have always wondered why they're so expensive. Are they really that great? To really get the benefit from them you would need to run a hotter coil and open the plug gaps further, correct?
Best plug wires 9K-sbc Engine 28 12-02-2014 09:12 AM
Plug wires atlantis Electrical 10 06-25-2011 09:15 PM
plug wires diamond mike Engine 1 11-18-2009 09:57 AM
What about these Plug wires? Dmaleck Engine 7 01-18-2008 03:38 AM
plug wires DoubleVision Electrical 6 03-19-2004 01:34 AM
