ok to run 70% water 30% antifreeze? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 06:59 PM
i was wondering if it would be ok to run a mix of 70% water and 30% antifreeze, since water cools better than antifreeze. my motors running a little hot and i thought id give this a shot. this much antifreeze is also good to about -18c* which is never seen where i live (coldest is like -10c). so would running this mix pose any problems or is it ok? will it run a little cooler? im also thinking of running some water wetter but well see how this works first...
Old 07-26-2005, 07:34 PM
347mustang's Avatar
go for it if it does not work than change back
Old 07-26-2005, 07:38 PM
what im asking is if i will run into any problems with corrosion or boiling over. what about something as low as 15% or so or even no antifreeze as long as it doesnt freeze?
Old 07-26-2005, 09:07 PM
4 Jaw Chuck's Avatar
Very little advantage going under 50/50.
Outlawed tunes from outlawed pipes
Old 07-26-2005, 09:42 PM
Steve karch's Avatar
I run 2-3 lt of antifreeze, 2 bottles of water wetter and the rest water. Works best for me this way. With electric fan the engine rarley see's 200 deg. Usually runs 180-190. I'm also running a 180 t-stat.
Old 07-26-2005, 10:02 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Right on. Actually, and I know I'm gonna catch flak for this one, the ratio at which maximum freeze/boil protection occurs is 67% antifreeze, 33% water. As ethlyene glcol won't boil, the heat absorbsion is quite good here. And there is enough watter to stop cold weather antifreeze gelling that can occur if there is too much antifreeze in the mix. After this %, the freeze protection actually diminishes. Well, not freeze, but it will turn into gel. Think of this, in the extreme heat of the desert, they run straight antifreeze, 100%, because of the heat absorbsion and the fact that it will not boil.
Old 07-26-2005, 10:59 PM
so what your saying is more antifreeze could make it run cooler? what is the exact ratio that the engine will run its coolest at? anybody know? and also, when does corrosion problems become a factor?
Old 07-26-2005, 11:06 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
I envy you , I always have cooling problems with mine and can never seem to solve it, even with dual electric fans.
Old 07-26-2005, 11:53 PM
A high concentration of anti-freeze does not make it run any cooler, it just makes the boiling point of the coolant higher. I ran 70% anti-freeze & 30% water in my '72 Nova for several years with no problems. It ran 230* or better with the A/C on and only "boiled over" immediately after a hot shutdown, but a $5 add-on recovery system took care of that.
Old 07-27-2005, 07:35 AM
Water is best for heat dissipation, antifreeze provides lubricant as well as decreases freeze point and increases boiling point. If you are running a high engine temp, changing to a higher water/antifreeze ratio will help reduce temps by better heat dissipation. If you live in colder climates then you will have to adjust your ratio accordingly as ambient temp approaches freezing. Water Wetter enhances the water's heat dissipation esp at higher temps. With the ratio's I am using, my engine takes longer to warm up and temp tends not to fluctuate as much as when I have a 50/50 antifreeze/water ratio. Keep in mind that pressure also increases boiling point. If you have a weak rad cap then you will potentially boil over at a lower temp. If you can keep you engine under 200 deg then boiling over is not a concern
Old 07-27-2005, 08:57 AM
347mustang's Avatar
i just do not under stand why so many people have cooling problems...i had a 92 s10 with a built 427 big block...i had a nice alum radiator..a good water pump and dual fans..it never even in july got over 185 degrees...do you know what nuclur power plants use to cool the nucluaer rods....pure water..thats cause nothing on earth cools better than water....the anitfreeze is just that,,it keeps your motor from freezing and helps a little with boiling and fights against rust..try pure water with some water wetter to keep rust away and the pump lubed...
Old 07-27-2005, 12:46 PM
so if i ran almost pure water (water wetter bottle says use 15% minimum anti if its a street vehicle so thats probly what ill do) and the water wetter took care of the corrosion problem id be good to go? what about the boilover factor with using this little antifreeze?
Old 07-27-2005, 01:12 PM
How hot is your engine running. Your going to have to hit at least 220 before a boil over and if your running that hot I think you have other problems to deal with. If you do as 347 and myself have done then boil over is a non issue.
Old 07-27-2005, 03:07 PM
what he said...water is more efficent in carrying off heat, in a well designed , well maintained system.
water wetter is a great product...for the compalnies that make it. If you want to break the surface tension of the water, which will increase its heat transfer abilities, add 4 or 5 drops of liquid dish soap (old farmer trick)
Old 07-27-2005, 05:12 PM
anybody know what temperature a 15/85 mix of anti to water would actually boil at?
454 Water pump recommendations. RObs71Nova Engine 5 07-20-2005 10:29 AM
Well water (iron in water) Automotive paint 1931 steve Body - Exterior 11 07-14-2005 09:29 AM
Basic fuse block rewiring y5e06 Electrical 2 06-02-2005 06:46 PM
Water Wetter and Anti Freeze Jag Daddy Engine 11 07-04-2003 07:25 PM
Timing/Water Injection Mertz Engine 7 08-20-2002 07:31 AM
