ok, th350 converter on a th350c - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 09:26 PM
fast68's Avatar
likes chevy trucks & boobies
ok i cannot find a th350c converter for the life of me, no shops have one and no stores either, and i have a perfectly good one sitting that i really need to use because it is the 9" tail length i need and i cant find a non C one,
what would happen if i hacked off the smooth third shaft(middle inside shaft) of the input and put a non lockup converter on it
would it be fine
if not then why not
thanks
Old 03-17-2007, 11:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
would it be fine
if not then why not
thanks
1. no
2. the splines are in different locations from a t-350c to a t-350..... close but different
« tranny | tranny id? »
Th350 Space between Converter and flywheel hiball Transmission - Rearend 2 05-26-2006 07:23 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 10:03 AM
Converter suggestions TH350 LeadfootBob Transmission - Rearend 4 12-30-2005 05:06 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 12:41 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-27-2004 12:32 AM
