-   -   Ok to use polishing compound on metallic paint? (http://www.hotrodders.com/forum/ok-use-polishing-compound-metallic-paint-73921.html)
tcruise 11-12-2005 08:06 PM
I did a quickie paint job on a new fender, using a blue metallic (single-stage) acryllic laquer out of spray cans. It turned out pretty good, but the finish is a bit dull.
Is it safe to use polishing compound on this? The paint can says you can use rubbing/polishing compound after a week, but I'm not so sure how well metallics will hold up. Thanks!
MARTINSR 11-12-2005 10:10 PM
No, you can not compound a metallic. It will cut thru the layers of metallic and make it blotchy.
tcruise 11-14-2005 12:13 PM
Polishing metallic paint
I'm glad I asked first!
baddbob 11-14-2005 02:30 PM
Sand what you have with 1000 grit wet then apply three more nice coats of paint. If the paint goes on with little to no texture you should be safe to lightly polish it out to a fair gloss. Use a light polish like 3M's old Finesse. Or you could apply three to four coats of lacquer clear and colorsand and buff.
The best way would be quit using lacquer products and switch to a basecoat/clearcoat urethane system.
