Ok to use polishing compound on metallic paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2005, 09:06 PM
I did a quickie paint job on a new fender, using a blue metallic (single-stage) acryllic laquer out of spray cans. It turned out pretty good, but the finish is a bit dull.
Is it safe to use polishing compound on this? The paint can says you can use rubbing/polishing compound after a week, but I'm not so sure how well metallics will hold up. Thanks!
Old 11-12-2005, 11:10 PM
No, you can not compound a metallic. It will cut thru the layers of metallic and make it blotchy.
Old 11-14-2005, 01:13 PM
Polishing metallic paint
I'm glad I asked first!
Old 11-14-2005, 03:30 PM
Sand what you have with 1000 grit wet then apply three more nice coats of paint. If the paint goes on with little to no texture you should be safe to lightly polish it out to a fair gloss. Use a light polish like 3M's old Finesse. Or you could apply three to four coats of lacquer clear and colorsand and buff.
The best way would be quit using lacquer products and switch to a basecoat/clearcoat urethane system.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
help wetsanding metallic paint?? imp0rted1 Body - Exterior 9 07-11-2008 11:02 AM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 10:41 PM
Glazing, Polishing, Compounding After New Paint! Help! Torx Body - Exterior 9 08-12-2004 07:37 PM
Metallic Paint - splotchy look bruce-77346 Body - Exterior 1 05-25-2003 08:09 AM
