Ok you hate the way my Nova front clip is attached - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2013, 10:16 PM
Other than starting over...how can I improve the attachment of my Nova front clip to a stock 1940 truck frame (poorly installed by previous owner).
Also, other than boxing the frame is there a way to install cross supports to the existing 40' frame and improve the strength. Not building a race car.....just a weekend cruiser.
ID:	70374   Click image for larger version
ID:	70375   Click image for larger version
ID:	70376   Click image for larger version
ID:	70377   Click image for larger version
Old 01-07-2013, 11:35 PM
techinspector1's Avatar
Wiki Edits: 326
Well it ain't real purty, but is it in there square and workable?
Old 01-08-2013, 07:04 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I, for one, don't hate the way it's installed. The clip is wider than the frame, thus the beast is born.
Do the tires stick out of the fenders? (Can't see if the front tires are mounted in the photo)
Old 01-08-2013, 07:17 AM
1940 Chevy truck
The front tires do not stick out past the fenders. The hood and fender set up may be wider than stock but the wheels seem to sit just right with good clearance all around.
Old 01-08-2013, 08:22 AM
Based on what I can see in the photo, and what you are describing, I guess I am not getting the "poorly installed by previous owner". Sounds pretty well thought out.
Are the engine mounts on the crossmember or the frame? The reason I ask is the front crossmember stiffens the frame a huge amount, compared to the stock set up. If the mounts are on the crossmember, or close to it, and you have a decent transmission crossmember, I'd think you are good to go as is.
Old 01-08-2013, 08:34 AM
RWENUTS's Avatar
The killer question is!!!!
Will it or has it passed inspection wherever you're going to drive it.
Old 01-08-2013, 03:27 PM
Inspections? What The ?? Oh, Yep... a Canadian.
Inspctions, We Don't Need No Stinkin Inspections...
Old 01-08-2013, 06:39 PM
1971BB427's Avatar
If you measure everything out and it is square, then I'd box the connecting point differently. I'm not sure I'm crazy about the two frames sitting alongside each other, although they may be strong enough. The blunt ends are not pretty.
I would cut plates that will make a more gradual transition from the two frames, and add them to what you have. Grind off anything that's sticking up past the frame's outter edge, so when you add the transitions it's smooth. These angled plates will further work as gussets and enforce the area further also, plus make it look more professional.
Just taking what you have now and making all the square ends angle out at 45 degrees and boxed closed, will make it all look better, and be stronger. Do the angles on all edges, leading, top, or wherever there's a difference between the subframe and existing frame.
Old 01-09-2013, 06:33 AM
Sounds like I may have options for improving the front clip
Thanks for all the comments and suggestions. I will definately spend some time modifying and re-supporting the front clip attachment on my 40' truck before considering scrapping the old work. Based on many of your comments, with a little extra welding and frame support work I think what I have is worth saving.
The truck sits nice and level and feels correct on the short quiet trips I've taken around the block. It may not be pretty but I think what has been done by the previous owner was well set up, level and sqaure.
Now I am after an "under bed" gas tank and an after market truck bed.
Hope to be on the road and legal by March 1st.
Old 01-09-2013, 07:16 PM
Originally Posted by 4garages View Post
Now I am after an "under bed" gas tank....
What's the width of your frame rails? Check this out, might be of use to ya! Rear Mount Gas Tank 63-72 Short Bed Step Side - Classic Parts Talk
64 Nova Front Clip local617 Suspension - Brakes - Steering 4 04-25-2011 12:53 PM
Nova or S-10 Front Clip? lt1_performance Suspension - Brakes - Steering 11 06-23-2009 05:50 PM
gm front clip,nova? blasterboy44 Suspension - Brakes - Steering 4 08-18-2007 02:45 PM
Nova Front Clip shortblok Suspension - Brakes - Steering 6 06-19-2007 02:05 AM
nova front clip beetle9 Suspension - Brakes - Steering 5 09-20-2004 01:08 AM
