Okay, what type of engine is this really? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 08:47 AM
Last journal entry: SO FAR...
Hello Guys
We need help to identifing this engine, we thought it was a 1600cc dual carb, not sure any more it doesn't look like any of the ones I have seen so far. It is in our new 1973 beetle, which over the years has been modified again and again...Help us please and thank you. (PS in the pic, the carbs. are off being cleaned)
Name:	DSC00729 (500x375).jpg
Old 10-23-2012, 09:19 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You can't tell what cc it is from the outside. To change the cc, you change the piston jug size instead of boring it out. It looks like a normal VW motor to me. The exception is the dual carbs that someone installed. The carbs you have should either be Dellorto or Weber.
Old 10-23-2012, 09:42 AM
Well here is more pictures with the carbs on, it just looks like such a tight fit we thought maybe it was something else we are having a hard time determining what it is for parts.
ID:	68551   Click image for larger version
Old 10-23-2012, 09:49 AM
You need to move into the VW "Community" and you will learn everything you need to know. I had a 72 bug a few years ago and I think this was the forum I use to visit. VWVortex.com - Air-cooled
That is one of the most simple motors ever, it won't take long to get with it. I think that is a hot rod distributor most everyone uses them, I remember a name something like 006 or something like that,but I think that is what it is. Unless you are going to change a ring or something knowing the exact displacement isn't important, it's a "1600" pretty much. The carbs and intakes are aftermarket, no big deal. Really, don't over think it, this is simplicity at it's finest.
The Following User Says Thank You to MARTINSR For This Useful Post:
wayin2art (10-23-2012)
Old 10-23-2012, 10:16 AM
thank you Brian, VW site is exactly what we need now. ( this is my husbands project and I am doing all the computer stuff.) he is busy grinding out the rust...thanks again
Tiffany
Old 10-23-2012, 09:48 PM
S10 Racer's Avatar
Back in my younger days I raced dune buggies and got well aquainted with those little VW motors. It's pretty amazing that you can make those things outrun a V8. The motors are very simple once you do one. Mine started out as a 1500cc stock motor. I changed it to an 1835cc with dual Dellorto carbs and nitrous. It ran great till I missed second gear once.
Old 10-23-2012, 10:14 PM
Wiki Edits: 27
I have a Vw dune buggy, a couple places I look is Chirco and Samba for VW info.
Old 10-24-2012, 08:49 AM
Wiki Edits: 31
In a '73 it should be a 1600 Dual port. Dual carb is a common and pretty cheap conversion. I would have done it to my '74 but the left side carb would not have fit with the autostick shift solenoid being right there..
The blower housing looks stock, just painted white and not black. I don't think the engine has had much work done to it. Usually the common upgrade is a degree indexed crank pulley. Makes it easier to time them
The Following User Says Thank You to matt167 For This Useful Post:
wayin2art (10-26-2012)
Old 10-25-2012, 09:02 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Looks like type I, which is what it comes with. Finding out the CC's, as stated, will require knowing what the internals are.
new type of engine design: two crankshafts Jon Hotrodders' Lounge 44 10-24-2012 03:18 PM
Type of Engine? 55GMC-Truck Engine 13 03-20-2008 09:01 PM
LS engine type Duke of Cruel Engine 9 07-16-2006 07:43 AM
What Type Of Engine? 91_Silver Engine 1 04-12-2006 10:20 PM
Determing engine type RAJ72 Hotrodding Basics 2 12-11-2003 08:53 AM
