Okay is this worth it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2004, 09:13 AM
New Member
Lightbulb Okay is this worth it?
I just got a camshaft from a friend of mine that sold his car before he could use it. He traded me it for a Ford carb. Its a Lunati and its got the #4 and the #7 backwards. I have been told this is a secret that nascar was doing for some time. What changes would I have to make to get this to work and is it worth it the specs are 232/ 236 at .50 duration and 510 by 520 lift with a 110 lobe sep. Would I change the spark plug wires to be the #4 on the #7 and vice a versa???
Ow and the cam i am using now is a comp 280 H magnum 230/230 at 50 duration and 512 by 512 with my 1.6 rockers.
Old 04-14-2004, 05:24 PM
New Member
nobody got any imput here on this ???
Old 04-14-2004, 08:49 PM
Swapping the 4&7 plug wires is the only thing required to make it work. From what I have heard, the biggest gain is a smoother running (less vibration) engine.
Old 04-15-2004, 08:27 AM
New Member
Thanks boss appreciate it.
Old 04-15-2004, 09:18 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
What engines is this trick (switch the 4&7 plug wires) good for? What needs to be on the engine (the kinky cam, or factory-style cam), and does a special crank need to be used (to put the pistons in the correct spot so you're not firing the plug off at the end of the intake stroke)?
Old 04-15-2004, 11:59 AM
firestone's Avatar
http://teamrfc.gospelcom.net
All you have to do is buy a 4/7 swap cam and swith the 4 and 7 wires. I have a friend that just built a 383 with a custom grind 4/7 swap cam from comp cams.
Adam
Old 04-15-2004, 12:47 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
I'd be interested to see some dyno comparisons between 4/7 swap cams and standards. How does it affect the powerband?
Old 04-15-2004, 01:31 PM
New Member
Okay the test is scqeduled and i will use the same engine for both tests. One with the lunati 7/4 cam and then a similar cam without . I think I saw a lunati grind with the same duration, lobe sep, and lift. I'll do it this weekend.
Old 05-06-2004, 08:48 AM
Wiki Edits: 7
this works for ALL v8 engines, right?
Old 05-06-2004, 08:56 AM
New Member
And a few V6's
hahah i couldnt help myself.
Old 05-06-2004, 12:00 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Same thing on chevy's 5 and 7. Provides a tick better fuel distribution. The two cylinders aren't fighting each for air.
Old 05-06-2004, 04:19 PM
Keep us posted on this one. I've heard everything from 5 to 25 horsepower with the biggest plus being a smoother engine.
