Old B&D Polisher 7"/9" any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2011, 07:33 AM
SuthnCustoms's Avatar
Crazy Ole Ironhead
i found someone selling a used Black & Decker 7"/9" model 6124 polisher for 50.00 with several pads to go with it,he claims these to be a high end type,these any good and worht the money?
Old 05-08-2011, 08:41 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you talking about the one on craigslist ? If so yes those was very good at one time and just be careful not to burn through with it if you haven't used one very much JMO hang around and someone else might come along with some input on it good or bad.
Or like this one . http://augusta.craigslist.org/tls/2366802512.html
Cole
Old 05-08-2011, 08:49 AM
Crazy Ole Ironhead
Yea thats the one,i live about 45 minutes from Augusta,i've used Polishers before several times but have an old chinese cheapo type for now
Old 05-08-2011, 10:26 AM
gto_ron's Avatar
B & D buffer
I've used one of the old B & D polishers for about 20 years. It's a quality American made product. This is before B & D started selling Chinese stuff. It's almost all metal, has a good adjustable speed-control and has plenty of guts for that first pass with cutting compound. It's an industrial-quality unit but it is a little heavy.
I bought this one new for ~$350 and it has been money well-spent. Mine is a model 6138, not sure what the difference is.
regards
Ron
Old 05-08-2011, 01:06 PM
The B&D polisher is definitely worth the price and I would have jumped on it without hesitation.
As for wool buffing pads, if they’re not Schlegel they’re only second rate pads.
Here’s a little insight on wool pads. White wool pads are used for cutting and the yellowish wool pads are used for polishing. White wool pads come curled on the outer perimeter and non-curled. Yellowish pads are only produced curled. Curled pads tend to burn through and rub through edges easier than the non-curled and catch mirrors, antennas, door handles and other pieces unintentionally. Moreover, on concaved bodylines or corners they tend not to fit in the groove to get a uniform finish producing an amateur result overall. Non-curled pads cost about 20% more due to production labor. To hold the outside perimeter intact requires extra specialized stitching otherwise the perimeter would just come loose and fall apart with little use.
I do use foam pads too. Disadvantage to foam pads is if you catch something unintentionally, goodbye pad.
Old 05-09-2011, 04:12 PM
milo's Avatar
point on positive
Check to see if it is a dial or trigger speed control..there will be times when you'll want to just creep along slow and the trigger type speed control is the one.. The dial type are hype
http://www.youtube.com/watch?v=pxFsG...E6A586&index=3
Old 05-09-2011, 04:30 PM
eloc431962's Avatar
Wiki Edits: 37
Here's the one he is looking at Milo.
Cole
ID:	55127   Click image for larger version
ID:	55128   Click image for larger version
Old 05-09-2011, 04:52 PM
milo's Avatar
point on positive
I looked at the parts list and don't see the dial so yes its a good one...
check it- > http://www.ereplacementparts.com/ima...4_Type_101.pdf
Old 05-09-2011, 05:28 PM
milo's Avatar
point on positive
again though it may be one of those set rpm type and the trigger is a on off instead of speed control
Update on the Dodge "Good ol' truck" project. Hippie Hotrodders' Lounge 9 11-23-2009 06:50 AM
Any good "shorty" spark plugs besides Accel? Cousin_Joe Engine 13 04-04-2008 08:08 AM
Is "Spot & Glaze" putty good for anything anymore? FrankR Body - Exterior 19 11-30-2005 03:18 PM
3 against 1 or "The Good Old Boys Remember Pearl Harbor" Centerline Hotrodders' Lounge 23 02-09-2004 08:20 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
