Old Cadi - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-24-2007, 02:14 PM
Old Cadi
Hi,
Charles from Scottsdale,AZ and it's 108 degrees today.
Old 07-24-2007, 02:27 PM
old cadi
I have already changed the original 1985 engine because of leak in the block due to casting. It now has a1987 4.1L in it. I keep loosing about a quart of coolant every 2 days ...but cannot see the leak when the car is running. If the replaced block also has a leak, I'm afraid to pressure test it ..because it may make the leak worse. I've tried numerous radiator stop leaks, but it didn,t help. Any suggestions?
Old 07-25-2007, 12:57 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Welcome to the site. Lots of info and opinions here. To get the most out of the site check out the Knowledge Base and use the search function for quick answers to your questions. As well check out the Project Journals for info and inspiration.
As this is the Introduction Forum you will get more exposure to your water leak problem by posting your info and question in the Engine Forum.
Glad to have you here and enjoy the site.
« New guy | RyanVille »
1989 Cadi starter won't turn over 1-bassman General Rodding Tech 3 11-19-2006 09:33 PM
60's cadillac engine rbfpezcore Engine 12 11-10-2005 05:13 PM
51 cadi channel 51 cadi Body - Exterior 0 08-02-2005 03:35 PM
'79 seville Rear end Posi??? MrChevyDC3 Transmission - Rearend 10 12-28-2004 10:11 PM
Update on the Cadi bowtiebabe72 Hotrodders' Lounge 9 11-27-2004 02:42 AM
