This Old Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2008, 03:16 PM
ratpackin's Avatar
Last journal entry: old setup pic-
This Old Cam
One of the few items in my 454 that survived seizure due to oil restriction is the solid roller from Competition Cams.
I purchased it in the mid 80's but has less tan 1500 miles on it.
The engine shop say's they could use this cam on in the new engine if I want. I just found the info on the old cam. -This is going in my '57
The new engine is a 489 stroker. 10.5 compression, aluminum AFR heads. Intake is still being decided but likely a Victor Jr. with an 850 carb. Transmission currently is a muncie, 4:10 gears in the rear.
Ok engine gurus... I'd like some input. Is this cam appropriate this larger engine - and street/strip performance?
-Thanks in advance
Old 09-10-2008, 03:55 PM
coldknock's Avatar
I'll second F'Bird's prognostication.
Larry
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
