That flywheel does indeed just pull off but unfortunately it's going to TIGHT!!!!! That thing is mounted on a tapered shaft and if you can apply some heat to flywheel hub it will come off a lot easier, just be warned that when it does come loose it will in all likelihood jump off all at once so be ready for that to happen.
Also it's quite likely that the retaining nut will be a left-hand thread.
