-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Old Dash out< New dash for gages. (http://www.hotrodders.com/forum/old-dash-out-new-dash-gages-77390.html)
AmericanPackMule 12-29-2005 08:24 PM
:D '73 Ford Ranchero -
New Sheet metal Dash For: 4" { 8.5 G Tach. & 150 M. P. H. Sped'o & "Vacuum" in tank for power brakes}
2" { Oil Pressure; Oil Temp.; Water Temp.; Exhaust Temp.; Trans Temp.; Trans. Pressure; Amp.; & Vacuum for dis.}
12 V. A.M. & F.M./ D.V.D. Pull out. & Toggle Switches For: Electric. Fuel Pump / Kill Switch / 12 V. Vacuum Pump. ~ Head Lights + Parking Lights / L. & R. Turn Signals. + Emerg. Blinkers. --- Ign. on/off ~ Push Button Start.
Key For: "All or Nothing."
After I put the new Circut braker bord in. & put the wires in one loom & Fluid carring tubes in another, with cables in another. Than...
How do I attach the new Dash?
matt167 12-29-2005 08:29 PM
use the original dash mounting places if you can. you could always weld it
