Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - old double hump heads
Old 06-18-2002, 07:12 PM
Paco's Avatar
Paco Paco is offline
You might pick up any streetrodder magazine and check out Billet Specialties brackets. They are also on the web. Alan Groves is another source for steel brackets,but I am not for sure they can be mounted without the use of the holes in the head. The Billet Specialties brackets mount off the water pump and the first two intake bolts on either head. They are polished billet aluminum and look great. They will allow for the alternator and A/C compressor. I use a Sanden compressor, don't know if a factory stock GM compressor will work or not.
