-   -   old double hump heads (http://www.hotrodders.com/forum/old-double-hump-heads-2764.html)
chale24088 06-16-2002 09:55 AM
I have a set of old double hump heads that do not have the holes bored for the alternator and the power steering pump. What is the best option for me ? To try to have them bored or have special brackets made?
helrazr3 06-16-2002 06:16 PM
i dont know what your using them for but if you can get the original exshaust manifolds the holes are there. those heads are mid 60s or earlier. there are also a few aftermarket companys that make brackets fof your conversion i cant remember the names right now but ive seen the adds in streetrodder and rod and custom magazines.good luck
chale24088 06-17-2002 03:23 PM
I have a 84 Z28 camaro with a 350 that has original heads I heard that the double humps would give me a few more horses. Please tell me if I am wrong...
Tom 06-18-2002 03:10 AM
I have several sets of those heads and found no problem useing them the only fabrication I had to do was the alternator bracket off the water pump but forget about the A/C. yes these heads will boost the horses and compression on your 84 350
1BAD80 06-18-2002 06:01 PM
Check the valve to piston clearance before you put it together. Or you mite have some bent valves and push rods. Most later pistons dont have enough clearance for the 2.02 valves plus any good lift cam.
George
Paco 06-18-2002 06:12 PM
You might pick up any streetrodder magazine and check out Billet Specialties brackets. They are also on the web. Alan Groves is another source for steel brackets,but I am not for sure they can be mounted without the use of the holes in the head. The Billet Specialties brackets mount off the water pump and the first two intake bolts on either head. They are polished billet aluminum and look great. They will allow for the alternator and A/C compressor. I use a Sanden compressor, don't know if a factory stock GM compressor will work or not.
30coupe 06-19-2002 09:28 PM
Also, you'd better plan to have hardened valve seats installed. The old heads are made for leaded gas. They may perform for a while, but it won't take long running unleaded gas and the valves will begin to recess in the heads. Unleaded erodes the valve seats pretty quickly.
tjk2000us2000 06-20-2002 09:08 AM
What casting number are they? I had a pair of 461X( the X is only on the underside) heads on a 71' 350. They seemed to work real well for me. As for the brackets I didn't have a problem finding something that worked for me. For the alt. the bracket bolted to the water pump and intake I think. I can't remember about the power steering but it worked.
Tim
oldcarguy85 06-20-2002 12:37 PM
these heads are great... i got teh 462s on my 327 and they are awesome. wth the 2.02 valves man they are sweet. anyway the brackets are no problem. go to any local auto parts store look in the mr, gasket crap. tehy have a litte pice that is attached by the header bolts and then u use an f braket for the alternator. then u can use any p/s pump off of liek any old chevy pickup that mounted down low on the two holes near the balancer. then a/c is kinda a challenge. i fabbed up a brakcet cause i couldnt; afford the march performance bracket. but those ore ncie brackets that march has and they ave them ofr eveyrhting.
