T 5 5 Speeds
rod and custom or street rodder magazine recently had an article about using newer transmissions from mustangs, camero's,etc, behind your flathesd. In the old days you wanted lincoln zepher gears and a Columbia 2 speed rear end, My drag racer buddies used to add full length roller bearings to the cluster gear to give more life to the old ford transmissions My brother did some machine work and ran a buick trans in his dry lakes 36 coupe It was torque tube and he said the ball radiius was the same, he drilled and tapped holes.
Old Ford Flatheads
I checked out the Hot Rod mag article you spoke of, Auto Gear. Holy smoke! that was more info than I could process!
As I said before, I'm not looking at serious racing. I just want to get a reasonably good flathead and goose it a little. I don't want to pour tons of money into a motor, or the rest of the car, as far as that goes. I'm basically looking at building a reasonable facsimile of a drop tank lakester that I can take out a few weekends of the year and run around on the dirt, and perhaps take to a couple of car shows. Right now, it looks like I'd like to bore it a little, port the heads, and get some domed pistons. They guys with the blowers and redoing the French blocks & so on is WAY more than I want to do or can handle! Thanks for the info on the Hot Rod mag article, though. It had a lot of good info. |
John L |
S10 T5 shifter
borg warner S 10 T 5 are also popular when using late model engines in older cars, they also have the shifter foreward, the S 10 shifter and housing can be adapter to other T 5's. Tremec' trans is a lot heavier duty. lots of options, gear, shifter locations, gear ratios. some jeeps used the Ford 4 speed Top loader, It had a top mounted shifter. Flat head to 4 bolt ford trans using a merc belhousing, and jeep shifter, just harder to find all the parts.
cheap parts
| caddy flatheads | shuswapbrent | Engine | 2 | 09-19-2010 12:26 AM |
| Ford Flatheads Forever! | Rat_Rod_Rider | Hotrodders' Lounge | 23 | 09-22-2006 10:27 PM |
| Ford Flatheads | Andy_SSPP | Engine | 2 | 07-14-2006 05:43 AM |
| Flatheads and Clevelands | JR66Ford | Engine | 1 | 10-12-2005 08:20 AM |
| Flatheads (again) | Oley | Engine | 1 | 10-18-2003 04:12 PM |
