old gas tanks - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 08:36 PM
old gas tanks
what is the best, easiest, cheapest , way to dissolve the black tar stuff in the bottom of this gas tank (' 49 F-5 COE ). The tank was behind the seat and has hardley any rust...................thanks
Old 04-18-2007, 10:05 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
If you type 'gas tank cleaning" into the search engine (at the top of the page) three pages of threads come up with info. Here is a link to just one of those threads:
Help cleaning Sludge in gas tank
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-19-2007, 07:08 AM
well, thanks again ''Brew''. I dd do the search before, but must have worded it different . anuway thanks again.......
Old 04-19-2007, 09:26 AM
next question :
one of the popular choices is muractic acid, which I am familiar with and have used before..New question : can I use OSPHO ( phosphoric acid ) in it after ,to seal it or will it NOT work in gasoline ?
Old 04-22-2007, 12:07 PM
RetroJoe's Avatar
Beats pickin' cotton
You can always take it to a radiator shop and have them boil it out. I did that with mine, then sealed it with Bill Hirsch tank sealer.
Old 04-23-2007, 10:14 PM
Muriatic acid...commonly found in the swimming pool supply section of most home centers.
Old 04-26-2007, 01:17 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Try a bunch of Pea gravel about the size of a dime. fill the bottom of the tank with it and "Rock" (no pun intended) the tank side to side with "heart"
This should "sand " the bottom clean after a time, then remove the gravel, and wash out with thinner, it should come out shiny clean If your up to a little elbow grease.
Doc
Old 04-26-2007, 05:45 AM
Gas will soften the tar on the tank,but gas is getting expencive to. You can brush on the gas and let it soak in,than scrap off with puddy knife.
Old 04-26-2007, 07:45 AM
thanks guys, it always helps to get more suggestions. and / or ideas......
Gas Monkey update: Discovery drops Rawlings Jon Off-Topic 140 11-18-2012 11:50 PM
how to properly build beer keg gas tanks jack s. hitchens Hotrodding Basics 12 03-08-2007 02:21 PM
Gas tanks chrisflock Hotrodding Basics 5 11-02-2006 01:08 PM
gas tanks for 1930 ford 5-window coupe bettylew Body - Exterior 5 01-13-2003 04:46 PM
Which Gas tank is Best?? HotRodMan Engine 1 09-06-2002 09:19 PM
