Old Gasser - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 05:57 PM
Old Gasser
My friend has a 40 Willis Coupe that he has had for the past 30 years. He is putting together a 392 Hemi, blown and injected. He needs to know the torque values for the main and rod bearings. It is a 57 or 58 Chrysler motor out of an Imperial, New Yorker or a 300, they all used the same motor I think.
Old 03-25-2006, 07:52 PM
Set Set is offline
Early Hemi Torque Specs Foot-Pounds
Camshaft Thrust Plate 15
Camshaft Timing Gear bolt & washer 35
Timing Cover 15
Connecting Rods 45
Cylinder Head Bolts 85
Head Studs 100
Distributor Clamps 15
Exhaust Manifold Stud Nut 25
Intake Manifold Bolt 30
Main Bearing Cap Bolt 85
Main Studs 85
Oil Filter Bolt 25
Oil Pan Bolt 15
Spark Plugs 30
Vibration Damper Hub Bolt 135
What's a Gasser? goneguy Introduce Yourself 1 10-17-2004 07:03 PM
Gasser lovers in the Chicago area, LOOK!!!! willys36@aol.com Suspension - Brakes - Steering 1 02-13-2004 12:07 PM
More Gasser stuff (Kinda long) Murff Suspension - Brakes - Steering 6 10-29-2002 11:39 AM
gasser front axle failura Suspension - Brakes - Steering 3 10-17-2002 05:32 AM
