old headlights with new wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2009, 06:56 PM
I have a 1951 F1 Ford truck with 7" Hi/low sealed beam headlights. I moved everything (engine, front axle, trans, rear end, steering wheel, computers, etc.) including the wiring harness from a 2003 Mustang GT to the truck. I cut the Mustang wiring at the headlight bulb and ran 3 feet of 18 gauge wire to the old headlights. (The 3 feet extra was because I tipped the hood). The Mustang wire size was much smaller than the wires at the old sealed beam three prong plug. Will the sealed beams and extra wire burn my Mustang fuse? What is the amps of the old sealed beam, Halagon, and the new lenes with H4 replaceble bulbs I see on the interner? Thanks
Old 10-11-2009, 11:30 PM
Joe G's Avatar
Registered user
The existing wiring (2003 Mustang) is designed to be used with #9007 bulbs which are rated for 65/55 watts.
If you get H4's that do not exceed this wattage rating, you should not have a problem. But some H4's (the ones that are not street legal) are rated as high as 100 watts - for these I would use additional relays, and heavier wiring just to be safe.
Sealed beam 7" halogens are also rated for 65 watts, so they should work with the Mustang wiring without any alterations. Of course, in 1951, the headlights would have been 6 volt, so you would have to replace them with 12v sealed beams if they're not already.
I never wire headlights with anything less than 16 gauge, I usually use 14, but that's just me.
If you get the headlight conversion kits, just do exactly what the instructions say and you should be fine.
Hope this helps...
home aluminium wiring - danger pigjamelectric Off-Topic 9 07-30-2009 09:58 PM
Relays on headlights kleen56 Electrical 38 04-26-2009 04:24 PM
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 10:30 AM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
