An old HEMI lives again - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2008, 05:36 AM
Last journal entry: A few ongoing projects
At the present time Iíve put all major projects on hold while a get a new shop built but have been finishing up a lot of little stuff like making a couple of engines run on the test stand and getting cams broken in.
Iíve got a 37 Dodge pickup project that slowly but surely is getting a bit closer to running. I got the long block for the build done a couple of years ago and it was on the list of things to do.
Sunday I was finally ready to make the engine runÖ..pumped it twice, hit the starterÖ. it cranked twice and it lit. Does it sound healthy. The cam break in went off without a hitch and the carbs seem to be very close.
One of the big things I wanted to do was see if I could make the race only 6 deuce intake streetable and I think I succeeded. The intake is a Weiand Drag Star that I modified for Rochesters with progressive linkage.
At least on the stand the engine is very responsive running on just the 2 center carbs and when I tweek the end carbs they seem to respond well.
It runs right one the thermostat temperature (180 degrees) and carries 20 PSI on a hot idle. The cam selection seems good too with a nice lope and good response.
Specs on the engine are:
1955 Chrysler New Yorker 331.
.060 NOSR JAHNs pistons (341 CI final displacement)
PAW Cam
Adjustable pushrods
Triple 5 heads
Weiand Drag Star Intake
6 Rochester 2GC carbs
Stock dual point distributor converted to Chrysler Electronic
Stainless steel shorty headers
BBC water pump conversion
6 Pac air cleaner (12 pac now I guess)
For now its got my spare 833 four speed stuff on it but Iíll eventually be running a 727 automatic in the 37.
Iíll be getting some more run time in on it over the next few weeks and do a little fine tuning on the carbs but I am very pleased with its first run.
The last picture is the Dodge in mockup a couple of years ago.
Name:	engine without aircleaner.JPG
ID:	32336   Click image for larger version
Name:	engine with aircleaner.JPG
ID:	32337   Click image for larger version
Old 09-08-2008, 09:47 AM
redlightning's Avatar
Nice job!
Old 09-08-2008, 04:40 PM
DoubleVision's Avatar
Very impressive.
Old 09-08-2008, 05:27 PM
Jmark's Avatar
Wow, can I come by and check it out?
Old 09-08-2008, 09:33 PM
If your ever down in the Sierra Vista area give me a yell.
Old 09-08-2008, 10:00 PM
techinspector1's Avatar
Wiki Edits: 326
I'd expect nothing less than perfection from you. You are the go-to guy for hemis. Outstanding job, simply beautiful.
Old 09-09-2008, 08:53 PM
Thankyou for the comments Tech, it means a lot coming from someone who has your experience, but when you have guys like Centerline on this board it tends to keep me humble (his site gave me a lot of information).
What's so special about a Hemi? windmaster Engine 143 08-20-2009 08:42 PM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
early hemi cuda project! need help shipping engines and building an early hemi thecountmc Hotrodders' Lounge 13 12-03-2007 05:21 PM
need pics for wiki articles: hemi engines, epoxy primer, etc. Jon Hotrodders' Lounge 3 08-01-2007 01:53 PM
2004 Hemi V.S. 2004 R/T Adrenaline_Fiend Hotrodders' Lounge 26 05-12-2005 01:25 PM
