Old HP vs New HP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2010, 10:09 AM
Mertz's Avatar
Old HP vs New HP
I am working on a 65 283 that is rated at 220hp with power pack heads. How does the 1965 horsepower rating compare to the current ratings? Is there a conversion factor that I can use?
Old 06-18-2010, 11:19 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The difference between the "old" ratings (better referred to as SAE Gross Ratings) and "new" ratings (SAE Net, used since 1972) is that SAE Gross was measured while the engine was under perfect conditions. There was literally the bare minimum of accessories attached and the exhaust and timing used would generally not reflect what it had when it made it in the car.
SAE Net is tested with all of the accessories, exhaust and emissions equipment intact to provide a more realistic number. Both were measured at the flywheel.
Generally, I would just multiply the Gross HP figure by 0.85 to get a rough estimate of the SAE Net HP rating at the flywheel. That would put the 220hp engine at 187hp at the flywheel. I don't claim it's the most accurate way of doing it but it'll get you in the ballpark.
Old 06-18-2010, 02:29 PM
Mertz's Avatar
Thanks that is what I was looking for.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
does the small block chevy have a "proper" name? Hoxviii Hotrodders' Lounge 62 11-21-2009 08:50 PM
eagle crank hp rating. engineman302 Engine 4 04-10-2005 05:38 PM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 08:54 PM
didn't know where to ask this but HP and TQ relationship? stonedchihuahua Hotrodders' Lounge 11 12-14-2002 04:02 PM
