Old Propane tanks - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2007, 04:13 AM
Old Propane tanks
I have a 10# and 20# propane tank that is past it's expiry date. I hate throwing anything away. Anyone have any good ideas as far as making something useful out of these tanks ??? Jack
Old 07-15-2007, 06:10 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sandblaster..fuel tank..just for two..Be careful about purging all the fumes out before you work on one so you do not blow yourself or the neighborhood up..
Sam
Old 07-15-2007, 06:12 AM
you can have them retested for about 10 bucks a pop or find someway to purge them completely and use them for auxiliary air storage and or a portable air tank or a mini sandblasting cabinet........BBQ grille the choices are endless.
Shane
Old 07-15-2007, 07:16 AM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I use an old 100# propane tank as a portable air tank. I find it much more useful than those little air bombs. It is just a little harder to carry around.
Old 07-15-2007, 07:38 AM
zim@Eagle Mi.
If they are old, they probably have the female thread connection. All the new ones have a male fitting. You can't get them refilled again without spending $$$ for a new valve.
Old 07-15-2007, 09:53 AM
Last journal entry: frame build
The valve is 3/4 pipe thread. screw it out and replace with a 3/4 ball valve and they make great air tanks or you can get them recertified and changed to the new valving and they make really super propane tanks.
Old 07-15-2007, 10:41 AM
Wiki Edits: 409
I use the valve that came with the tank. It has a built in relief valve I have a bung that screws into the valve and it has male threads on the other side. I put a fitting on that side that has a provision to fill the tank just like a tire that I use if I am away from home and I need a little more air in the tank. I also threaded in a female quick-release air fitting that I can snap a hose into or I use that to fill the tank at home. I have several old hundred pound propane tanks so I can carry more with me if I have a need for more air at a remote location. The bung threads into all of them so I can easily switch tanks.
Old 07-15-2007, 03:15 PM
Sam
The sand blaster sounds interesting. Do you mean as a portable air source or what ???
Old 07-16-2007, 06:40 AM
zim@Eagle Mi.
Ya tell us more about the sandblaster part.
Old 07-16-2007, 07:34 AM
Wiki Edits: 3
Use the tank for the sand pot in a pressure blaster..one needs to have one of the larger tanks though to hold enough sand to be worthwhile..
Sam
Old 07-16-2007, 10:24 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Sam
how-to plans? Making tools are fun! Using the tools we made are more fun!
Old 07-16-2007, 03:48 PM
zim@Eagle Mi.
In other words, work it out ourselves?
Old 07-16-2007, 04:12 PM
Wating paitentally I might have to try this
Shane
Old 07-16-2007, 04:27 PM
zim@Eagle Mi.
Be prepared for fAILURE.
Old 07-16-2007, 04:55 PM
Sorry to hear your having computer problems.
propane tanks PropanePower Body - Exterior 1 07-17-2007 06:13 AM
Dual gas tanks with EFI dh79 General Rodding Tech 9 01-13-2006 07:40 PM
Octane ratings in USA DannyW Engine 16 07-01-2005 12:32 AM
351M on Propane... Fuel Mileage!!! offroadin Engine 20 09-26-2004 10:12 AM
97 Chevy Vortech on propane?? scheetz93 Engine 5 06-09-2004 07:25 PM
