Old question....new problem....driveline angles?
Guys,
I've had several people tell me that the ideal drive angle for my combination....4L60E and C4 IRS would be between 2.5 and 3 degrees. The rear end wont be any problem....but darn if the transmission is close enough. I'm at 5 degrees. I cant raise the transmission any more....and cant lower the motor without notching the top of the frame (A/C clearance). I really dont want to go with a different pulley system. I know to angle the rearend pinion at 5 degrees opposite of the transmission so theyre center lines are parrallel. No problem there. But.....do you see any drive line problems down the road for me? I'm not going to mind replacing u-joints....but just wanted some thoughts before I commit to finish mounting the rear end. Also, I think I found the answer by doing a search but I still want to ask. I plan on cooling the transmission with nothing but a pair of dual pass 18" heat sink style coolers from Jegs. Think it will be suffient enough? I'll be placing them on the inside of the frame rails....away from the exhaust. My exhaust is going to be under the running boards....of all places. There actually is plenty of room. Thanks, Dave |
I wouldn't worry too much about your "U" joints. The longer the drive shaft the lower the working angle the "U" joints will have. If it was a "T" bucket with an 18" drive shaft then there might be reason for concern but a full sized rod you should not have a problem.
When it comes to trans coolers I always use the style that mounts in front of the radiator. Never used the frame mounted versions so I don't know how well they cool. |
Thanks Centerline. Dave |
Thanks so much. Dave |
I run all my car's with frame mount cooler's,And never ever had a problem.I ran them on 350 turbo's and 400 turbo's.And will keep using them.
And down here it get's very hot in the summer time.
| blower idle rpm problem | Ratoflic | Engine | 7 | 12-01-2008 03:31 AM |
| Valce cover Oil leak problem / PCV system question | hotrodf1 | Engine | 7 | 05-01-2007 02:44 PM |
| Hotrodders Guidelines -- READ ME | Jon | Hotrodders Site Suggestions and Help | 0 | 06-14-2003 05:07 PM |
