Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - old red primer removal
Old 10-09-2012, 07:35 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
The reality of stripping is , these are ALL good ways to remove paint and primer and I use them all it all depends on the job and the type of material your trying to get off so you'll have to experiment a little to see what works fastest and cheapest start with a small amount of thinner and a small amount of stripper dont buy in gallons or a full box of sandpaper untill you know.and start with the roof or even better the hood because you can remove it and set it at a comfortable height .also when using thinner and stripper theres nothing to tape up just go to town on it,you dont want any getting in the jambs and making a mess. the proper set up and prep for using stripper without any mess is for a later discussion when and if its determined this works best but for now remove the hood and work on that...
