old red primer removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2012, 06:09 PM
Hi,
I have a 40 Chevy truck and am trying to remove the paint from the doors and roof.
I have tried a 7" sanding disc on my buffer and 40 grit on my da.
the top coat of paint(bake on original lol) comes off quite easily with the da.
Its the primer underneath thats a bear to get fully off.
Do i need to take it fully off?
can i cover it with epoxy primer and would it be fine?
How did you take the old primer off your vehicles?
Thanks!
Barry
Old 10-07-2012, 07:17 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Personally, I don't deem it necessary to strip to bare metal. Sand the original primer thoroughly with the D/A and then clean and prime as you normally would.
Old 10-07-2012, 08:33 PM
i guess if the epoxy adheres to the red primer, it should be fine.
i should try to get as much of it off as possible tho.
Old 10-08-2012, 06:06 AM
novafreek6872's Avatar
Nova Guru
I say take the time to strip it. Its only ONE vehicle !!
Old 10-08-2012, 06:10 AM
deadbodyman's Avatar
Wiki Edits: 11
Try lacquer thinner and a scuff pad keeping it nice and wet ,wiping it off as you go(like W&G) or the goo will turn back into primer when the thinner evaporates ,wear gloves...yes it does matter,to get the best results it has to go to the metal, otherwise why bother in the first place.,
Rol-loc strippers work good in the jambs also..
Old 10-08-2012, 08:26 AM
ok. will try the lacquer thinner way.
i agree. i only want to do this once!
Old 10-08-2012, 09:04 AM
Nova Guru
dont forget aircraft stripper too... have you tried that?? You can get it in spray cans...very convenient
Old 10-08-2012, 11:32 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I like the stripper and a tip when using stripper is to get some cheapy plastic drop clothes and apply the stripper and then cover it with the drop cloth and let it work for a while then the paint will wash right off..Just do an area at a time..
Sam
Old 10-08-2012, 08:25 PM
mitmaks's Avatar
Last journal entry: Grille
40 grit is too agressive, use 80 grit and gear driven sander, a.k.a. "mudhog" it'll strip down paint FAST
Old 10-08-2012, 08:54 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I have had good results using Norton RapidStrip Discs... Discs - RapidStrip
Old 10-08-2012, 11:25 PM
where do you buy your rapid strip discs at?
for the 5" bear strip discs to fit my 5" grinder, Acklands wants 37 bux each!
Old 10-09-2012, 06:13 AM
Wiki Edits: 11
Sam
Id start with some stripper just in a small spot,let it sit a while and try using a razor scraper insted of a putty knife to scrape the primer off. (tip rub the fresh blade against some glass to get a burless edge like an old fashond barber does when giving a shave...This will keep the blade from catching and gouging ,change the blade often so you dont put gouges in the metal....
sometimes the stripper dont work so well and the lacquer thinner works better get 5-6 rags and soak them set them on the surface and cover them with plastic this will soften the old primer up enough to scrape it off with the scraper until the thinner evaporates so be quick keep sliding the pile of rags around and scrape whats under them, rewet the rags once in a while to keep them wet.
Once all that is done wet a scuff pad with thinner and all the rest will come right up be sure to wipe clean as you go or when the thinner drys it'll turn back to primer again...when its all off use a lot of W&G remover and wipe everything down well 2-3 times then start sanding using 80 DA or 180 DA or anything inbetween is fine,when thats done another good cleaning with W&G and its ready for epoxy primer.
Old 10-09-2012, 06:35 AM
Wiki Edits: 11
The reality of stripping is , these are ALL good ways to remove paint and primer and I use them all it all depends on the job and the type of material your trying to get off so you'll have to experiment a little to see what works fastest and cheapest start with a small amount of thinner and a small amount of stripper dont buy in gallons or a full box of sandpaper untill you know.and start with the roof or even better the hood because you can remove it and set it at a comfortable height .also when using thinner and stripper theres nothing to tape up just go to town on it,you dont want any getting in the jambs and making a mess. the proper set up and prep for using stripper without any mess is for a later discussion when and if its determined this works best but for now remove the hood and work on that...
Old 10-09-2012, 07:39 PM
You can get them online @ Amazon for about $12 each or at Sears. I use them on my 4-1/2" angle grinder.
http://www.sears.com/norton-rapid-st...p-00967581000P
Old 10-09-2012, 09:02 PM
asked at work about some of these discs and we didnt have any.
But! we have a box of 3m bristle discs!
brought one home, slapped it on the grinder and zoom! primer gone.
one must go slow and move around alot as not to heat up the pannel too much but it works great.
Will work on it this weekend.
Rust removal and treatment in the UK - Epoxy Primer - help/advice please rossyl Body - Exterior 2 06-17-2011 10:11 AM
primer/sealer color under red? freethinker52 Body - Exterior 7 04-20-2011 12:54 PM
Ditzler DZL-72 red oxide primer-surfacer mitmaks Body - Exterior 6 04-07-2007 11:23 AM
red oxide primer uncle dave Body - Exterior 2 07-01-2006 12:16 AM
Red Oxide Primer 55ford Body - Exterior 16 01-06-2005 03:32 PM
