Old Regulator Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 10:24 PM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
I replaced my alternator with a GM 1 wire ( I know, 3 wire is better ) and I want to remove the old regulator. I am having toruble understanding how i can just remove the regulator and still get power to my accessories. Does the power not go from the regulator to the various systems in the car. I took a wire from the battery and ran it to the battery terminal on the ignition switch but I don't believe that i'm going to have power to the rest of the car. My pos. cable from the battery goes to the starter solenoid and then I've run a wire from the battery to the ignition switch. Am I going to have to run arother wire to the horn relay to supply the rest of the car, if so, what would that relay look like ? Sorry for being so uninformed but I haven't had much experience with this type of thing .. Thanks for the help..
Old 04-17-2012, 03:47 AM
EOD Guy's Avatar
From Doc's articles
Oxygen regulator converted to air regulator deadbodyman Garage - Tools 15 04-28-2012 07:53 AM
"Basics of Basics" Window regulator spring removal. MARTINSR Body - Exterior 0 11-24-2008 08:24 AM
Convert External Regulator To Internal Regulator 83F150 Electrical 1 05-18-2008 08:10 AM
Regulator removal wiring issues tjh211 Electrical 7 09-05-2006 12:05 AM
