Old School Coil Overs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 09:28 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Hi all,
Has anyone ever heard of Andeck coil over shocks. I have a set on my old chassis that was built in the late 60's early 70's. They are a smaller diameter than todays coil overs but their bigger than say a motorcycle shock.
I have heard that Andeck made dune buggy parts and other accessories for cars. They are stamped Andeck 2911 are chrome and they were made in Japan.
Thanks.
Old 11-01-2009, 04:59 PM
What if you decide you need stiffer or softer springs? Where might you expect to find them?
By the way, are coil-overs really old school?
Old 11-01-2009, 08:07 PM
1930u's Avatar
I know these worked well on this chassis.
I didn't know for sure that's why I posted. Since I posted though I've confirmed that the ones I have are VW design and were used on dune buggy kits. I bought 4 of them yesterday.
I only referenced old school because the drag chassis is old school. coil-overs have been around forever
Great points thanks.
9 inch ford G body rear axle questions, advantages STD spring, coil over eatonde Transmission - Rearend 9 01-21-2009 11:11 AM
at what age is a little girl old enough to spank with a belt? bullheimer Off-Topic 52 10-28-2007 07:03 PM
Anyone Ever Used Variable Rate Rear Coil Overs? JohnTN Suspension - Brakes - Steering 0 06-08-2007 12:42 PM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 04:15 PM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
