Old School Electrical Wizard Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2008, 04:42 PM
Gentlemen, I have a detailed post in the ENGINE forum. It is 68 Mustang 200 6cyl Stall Problem, under my jmacs53Willys name. As time allows could you please read and respond with your technical advice for things for me to check. I believe I covered the required info requested in your how to post electrical questions. I am no dummy with electrical things but have been told I get tunnel vision with some things and I believe this is one of them? Friday 11/14 is my day off and when I will to get back to the Mustang. If there is anything you can add that might be relevant to my inspections and testing, please feel free to advise! I'm 55 and have been working hands on American Rigs since 1964. I am a Chevy guy all the way and have hard wired my 53 Willys Wagon ground up without any problems EVER! This Mustang is absolutely all original and unmolested with most things underhood rebuilt or replaced to original specs. I assume this problem I'm having is something simple that I'm overlooking? Not being knowledgeable or too experienced with Fords has got to be it? Thanks John
Old 11-14-2008, 08:07 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
John, the fact that your car runs for a short time then quits - and you're satisfied that this isn't a fuel problem - has me thinking it's the condenser.
As I posted in your other thread, try disconnecting the condenser to take it out of the picture and see if it runs properly.
Old 11-14-2008, 09:49 PM
Re-coil?
I have seen some old coils short out after warming up. If the condenser don't fix it, substitute in a different coil.
Steve
Old 11-15-2008, 05:32 AM
Thanks for the come back guys! It was the resistance wire in the original harness. Runs great now! More detail in the original engine thread. Thanks again, you were right on!
Old 11-16-2008, 06:33 PM
Semloh - Look here
Semloh, Thanks for responding. The original thread is in engine forum listed as "68 Mustang 200 6cyl stall problem. There is alot of prior dialog to review if you like? I would be interested in your experience opinion as to what has been determined and prognosted. Thanks John
I try to check threads daily.
How To Submit A Post In Electrical Forum docvette Electrical 0 04-25-2006 05:46 PM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 06:41 PM
Electrical Advice willowbilly3 Electrical 25 12-26-2004 10:11 AM
Thomson Education Direct High School Program nightrain_rod Hotrodders' Lounge 4 08-12-2003 10:08 PM
