Old style radiator new style motor.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 04:19 PM
So i have a 1953 f100 radiator i want to hook upto a 351w. I'm a bit confused on how to make the 2 work.. The radiator has 4 necks for coolant hoses (2 on the the top and 2 on the bottom).. But you only need and inlet and outlet for the windsor motor.. So does anyone have any idea how i would go about making that radiator work with the newer motor? I was thinking i could have someone weld up one coolant neck on the top and the bottom.. But i'm really unsure how those radiators were intended to work?
Old 06-01-2008, 04:32 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Back in the day, that's exactly how it was done when switching from a 4 hose motor to a 2 hose motor....meaning seal off the 2 you don't need.
I am positive that it is still being done today by some. A friend has the same deal on a 34 ford with a SBC and it cools fine. (lots of folks say it won't work....or say: why cheap out?)
Old 06-01-2008, 04:34 PM
F&J F&J is offline
Also, use opposite sides, rather that using the inlet and outlet on the same side. It may still cool ok that way, but it's tons better when opposite.
Old 06-01-2008, 06:35 PM
What you have is a radiator for a flat head V8. These used dual water pumps, thus the pairs of inlet and outlet bibs.
Your choices are to use one of each top and bottom bib and plug the unused one. Or construct a Y or T manifold out of copper plumbing parts or welded steel tube to split the out going flow at the top to both inlets and do the same at the bottom for the outlet into the pump. You could do the same with large diameter stainless braid hose and fittings, but this is the high price spread, though would look beyond cool.
Bogie
AR RACING 383 Motor 64Duece Engine 27 05-20-2013 01:02 PM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
A quick question about titles and legal stuff. rusty105 Hotrodding Basics 71 05-04-2007 09:13 AM
motor won't come out.. Trav Engine 42 03-02-2004 07:16 PM
