We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 12-08-2005, 09:46 AM
fat40's Avatar
fat40 fat40 is offline
old style starter gm to new style
I have just changed engines in my 40 ford from a 1968 chev 327 to a 383 .So I will not be using my old style starter .Going to a new gm small style , what I am would like to know is the resistor wire on the old style starter going to cause me any problems not being connected . If so where does the resistor wire on the old style go to in the wireing harness , and what do I have to do to be able to use the new starter ?
fat40
Old 12-08-2005, 01:57 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The wire just bypasses the resistor for an old style points type ign. This gives a full 12 volts while cranking. Not needed on newer (HEI, etc) ign systems.
Old 12-08-2005, 05:26 PM
docvette's Avatar
docvette docvette is offline
docvette's barnstar
Wiki editor
Last wiki edit: Rebuild an alternator
Wiki Edits: 12
Doc here,
The new style solenoid will not have a "R" or "I" terminal on it.This is the secondary ignition terminal.
If you have an uninterrupted source of power to the HEI, (12 volts that does not drop out when you switch the Ignition to "Start") This wire is not used.
If you have a ballast resistor, and an HEI , (and it actually runs) Get rid of the resistor, it will run 100% better.It is not used for HEI...and if hooking up for the first time in the new body, It may not run at all.
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 12-09-2005, 09:17 AM
fat40's Avatar
Thanks for the imformation , I am running a mallory unilite distributor now with a ballast resistor before I install the new motor and new starter so you say I can do away with the resistor ?
Fat40
Old 12-09-2005, 06:03 PM
docvette's Avatar
docvette's barnstar
Wiki editor
Wiki Edits: 12
Doc here,
If your new engine is running an HEI type Ignition, you do not need the ballast resistor.
If you are running an aftermarket ignition, refer to your installation diagram, Some require them and some do not.
To use one where it is not needed, will cause no damage, but make it run poorly, or not at all...
To NOT use one where required WILL cause coil damage, and componet damage, in addition to poor performance after a short period of replacement time.
Doc
Innovations
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "old style starter gm to new style"
Bench testing a GM starter schnitz Electrical 10 07-14-2005 02:32 PM
GM remote mount starter solenoid kit malibuman66 Electrical 1 09-04-2004 01:19 PM
new style GM antifreeze beware zonk General Rodding Tech 34 07-26-2004 02:09 AM
New style starter, old sbc engine? Walker Engine 2 08-14-2003 05:16 AM
GM Starter Solenoid Amp Draw jamnut Electrical 2 07-21-2003 11:45 AM
