old sun tachometer hook up from garrell.770 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2011, 05:32 AM
garrell.770's Avatar
Last journal entry: More Of My Rides
i want to install a vintage 1960s sun tach in my 19
39 chevy truck hot rod, but i do not remember how. it has a red, black, white and green wire. which two are the rpm sensors? will the tach work with an electronic ignition? let me throw two cars i used to own, a red 1967 SS impala with a factory 427, four speed, 4:10 gearing.i bought it when it was four years old and it was immaculate, no accessories except for power steering. a 1963 split window corvette, FUEL INJECTED COUP that was seven years when i bought it. heck, lets make it three cars. a 1963 409 red impala,SS again all low mile original cars. two were bought for under 1200. dollars and the 409 car for 10.000 that i traded for a new 1993 indy pace chevy truck, even. some advantage to being older. thats all folks, thanks. garrell.770 alias hotrod truck
Old 08-27-2011, 05:58 AM
I have some stories to. And I have some old ones too!
Old 08-27-2011, 05:44 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
the red is the hot wire the black is ground the white is for the light and the green wire is for the goes to the distributer
Old 08-27-2011, 06:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2.
RED= Hot
Black= ground
white= light
green= distributer
Cole
Old 08-28-2011, 02:36 AM
Old 08-28-2011, 02:09 PM
Hoptup32's Avatar
The original Sun Tachometers needed an EB Transmitter to function properly. While you could still use the correct transmitter with a points ignition system, the internal batteries for these transmitters are not available any longer. You would have to build a circuit to stepdown 12v to the required 1.35 volts needed. To be used with an electronic ignition system the transmitter would have to be converted for this purpose. There are several gauge restoration companies that will convert the transmitters for electronic ignition use.
i have come a long way! from garrell.770 garrell.770 Introduce Yourself 2 08-24-2011 09:28 PM
how to hook up my tachometer JLBpontiac350 Electrical 9 05-04-2011 06:43 PM
GM tachometer litdoc Electrical 3 05-16-2010 12:05 PM
Sunpro tachometer, hook up questions eric32 Electrical 5 03-03-2009 08:03 PM
Tachometer 65Stanger Engine 3 05-07-2006 02:56 AM
