Old SW tach wiring./compatability with HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 04:44 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
I've got an OLD Stewart-Warner "Stage I" tach. that I'd like to use, and no wiring diagram so I need a question answered. I tried previously to have it hooked up to my HEI (from Tach terminal) and seem to recall it would only read to 2000 rpm or so. Wiring from case is as follows: 1-red={Signal/Input I believe},and 1 each of black and green that are twisted together. Green changes to white on front side of circuit board and would appear to be activation for field.) Does this sound right? Does anyone know if these older models of SW required any "black-box" (like the old Sun tach.'s) to work correctly or are they direct-wired compatible with HEI?-Thanks,Jim
Old 06-21-2008, 07:58 PM
Holder350's Avatar
Auto Parts Professional
All the SW tachs I'v seen the red is power black is ground and GREEN is your signal.
Don't know about the compatibility but I do know the old dwell meters wont work on a HEI without a filter.
HEI tach pulses vicrod Electrical 1 11-26-2005 01:39 PM
HEI and factory tach Impalatom Electrical 3 06-26-2005 09:00 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
HEI Tach Connection Sweet-34 Electrical 1 04-13-2004 03:40 PM
HEI w/ mech. tach drive for 71 big block vette 71 vette Electrical 2 09-30-2002 03:31 AM
