old tech equipment on new tech ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2006, 08:27 AM
FASTFORD's Avatar
old tech equipment on MSD & Mallory ?
i have a POWEREADY tune up/system analyzer unit from the 60/70`s. i haven't used it for a year or 2 but now i want to go over my car since i installed a new carb. the car has an MSD 6AL & Mallory Unilite in it.
my question is, can i use my old TECH equipment without ruining it on the new hi-tech ignition ?
this unit has the following testers:
a primary analyzer (test battery voltage,coil resistor,ignition switch,cranking voltage,charging voltage,primary resistance,point dwell,idle speed).
ignition analyzer (coil polarity,power balance,carb balance, plug wire testing)
combustion analyzer (carb tests)
charge/start analyzer (cranking volts/amps,alternators)
timing light unit and a tachometer.
HELP , thanks.
Old 04-18-2006, 02:34 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Does the car have (2) ignitions systems, MSD & Mallory???
You can use everything except the point dwell and tachometer.
For adjustments like advance curve, you will need to follow the factory instructions for the specific ignition system you are using.
vicrod
Old 04-26-2006, 10:14 AM
FASTFORD's Avatar
the car is using an MSD 6AL box with the Unilite dizzy .
i tried to use the testers,nothing works.
i will look for someone to check out the testers.
thanks for the reply.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Hotrodders Knowledge Base: General Rodding Tech Jon General Rodding Tech 0 11-26-2005 06:43 PM
BS Tech Support Delirious2000 Engine 2 07-27-2004 09:44 AM
