Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-22-2005, 12:15 PM
78transam 78transam is offline
Old TH350
Hello, Could any one please tell me if a TH350 transmission, that has not been used in 8 years would still work properly. It worked fine when it was last used.
I am hoping to swap the 403 V8 and transmission from a 1978 Firebird with my 78 Firebird. Any advice would be help full, as I live in the UK and cannot easily find another TH350 or advice on it. Thank you.
Old 10-23-2005, 12:01 AM
CHEVY4LYF's Avatar
CHEVY4LYF CHEVY4LYF is offline
'86 Camaro IROC-Z
TH350 quest.
I'm sure you'll be fine. I have an old '75 Nova that has a TH 350 in it and it has set for years at a time before and still ran. As long as it wasn't sitting in water or some such thing, it should work fine. I would however, change the tranny filter and fluid in it before you run it.
By the way, are American cars popular in the UK?
John
Old 10-23-2005, 01:56 AM
Landau454 Landau454 is offline
John
I agree about the fluid and filter change. After the swap drive very easy for a short distance then let it sit for a few hours to let the clutches soak up the fluid. They dry out somewhat from the years of sitting and need to be redampened. If you go out and hammer on it right away, it may toast the clutches.
Old 10-23-2005, 05:15 AM
Re: old TH350
Thanks for the advice, very useful.
Old 10-23-2005, 08:10 AM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
Put a new front and rear seal in it too.......................might have dried out.
IGNORE TROLLS & THEY WILL DISAPPEAR
Ontario Rodders
Old 10-23-2005, 12:10 PM
re: Old TH350
There is one more question I have before I buy this transmission.
I am I am a bit unsure about the compatibility of the GM TH350 Transmissions.
I was told once, that GM had two different bellhouse designs, a one for Chevrolet engines and one for Buick-Olds-Pontiac engine. Is this true?
So then is the TH350 transmission from a 1978 Pontiac Trans Am with the Z coded 400 cu in compatible with a 1978 A coded 231 V6?
I thought I understood it, but I don’t. I need to make sure that I don’t buy a transmission that won’t fit my 231 V6 engine.
Thank you.
Old 10-23-2005, 01:12 PM
Centerline's Avatar
Centerline Centerline is online now
HotRodsAndHemis.com
Last wiki edit: Mopar Tapered Axle Rear Brake Conversion
Wiki Edits: 49
There were two basic trans bolt patterns for the TH-350. One for Chevrolet and one for Buick, Olds, and Pontiac (BOP). A Chevy TH-350 will not fit a BOP and vice versa without an adapter. Check HERE to see the difference.
Old 10-23-2005, 02:39 PM
poncho62's Avatar
Wiki Edits: 5
However, there were some made with both patterns.................
Ontario Rodders
Old 10-23-2005, 03:53 PM
Crosley's Avatar
Crosley Crosley is offline
Last wiki edit: Transmission holding fixtures
Wiki Edits: 1,476
there is also a factory t-350 that is missing a bolt hole & part of the bell housing on the upper driver side that was used in V-8 Monza and brothers in the same car platform used in Olds , Pontiac.
Spank My Marketer
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Old TH350"
ThreadThread StarterForumRepliesLast Post
th350 to 700r4 swap??????????trumickTransmission - Rearend609-23-2005 09:19 PM
TH350 to M21 or TH350 to 700R4thecamaroguyTransmission - Rearend602-10-2005 02:18 PM
85 camaro 700r4 to th350drewkuchTransmission - Rearend511-09-2003 10:48 AM
picked up TH350, PG -> TH350daromTransmission - Rearend403-16-2003 10:06 AM
TH350 Rebuild Help!!!!!!!!!!McRydeTransmission - Rearend211-17-2002 05:32 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
