Old truck parking brake location... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 07:33 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Looking for guys with trucks that have used the Lokar parking brake located next to floor shifter. I know they mount on the floor or the trans. I'd like to free up the space where the original hand lever was mounted under the dash on the driver's side,(in my journal pic, you see I've temporarily mounted fuse panel on firewall there). Mounting it on the passenger side of floor shifter seems inconvenient, however, living in FLA with an automatic transmission, I won't have to use it that often anyway....again looking for feedback good and bad from those who have or had this setup.
Thanks,
James
Old 11-14-2011, 07:38 AM
delawarebill's Avatar
bk lever
there is no room in a Tbucket either.. thats why we mount them sideways just in front of the seat... just an idea...
Old 11-14-2011, 08:08 AM
Hwyhogg's Avatar
..ooops, guess I should add...my truck is a '56 Ford Panel
Old 11-15-2011, 09:19 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
In a nutshell, all you really want to have is a brake handle that will grab two cables or a single and lock it into place (set the brake) so the vehicle won't roll.
This can be accomplished in a number of ways, one of which was explained about the T-bucket. Another is to use a brake handle from a mid-60's IH 1600 truck E-brake handle. It uses an over-center handle to lock the E brakes. The Lokar E-brake is a simple and effective design that uses a 6 to one pivot lever to pull on the cable and a locking lever to apply tension to a toothed ratchet.
60's and 70 Mustangs had a unique toothed half ratchet E-brake between the seats that is short and effective. check out your local boneyard!
Parking brake cable parts for light truck rear end? ht d rd jk Suspension - Brakes - Steering 4 07-04-2011 10:20 PM
1957 Chevy truck parking brake racer819 Suspension - Brakes - Steering 1 07-18-2010 04:11 PM
Parking brake Bart Hotrodding Basics 1 05-28-2008 02:23 PM
Mecanical disc brake caliper for parking brake? bigun Suspension - Brakes - Steering 4 12-15-2005 08:43 PM
parking brake eneas kid Suspension - Brakes - Steering 4 11-27-2005 04:12 PM
