Old TRW 327 pistons info! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 03:23 PM
I have a shortblock 327 with a set of .060 TRW pistons part #L2250A. They were not in speed pro's catalog. They have a .500 dome. I was wondering what the advertised compression ratio was on these using 64cc heads. Guessing 13.1 Any help would be appreciated.
Old 02-24-2008, 06:44 PM
DoubleVision's Avatar
Try This:
http://speedtalk.com/forum/viewtopic.php?t=8664
Old 02-24-2008, 11:19 PM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
G'day camaro421sbc,
You'd be fairly close with your guesstimation of 13:1 with 64cc heads. You can mill quite a bit of material off these pistons to reduce compression ratio. If you get them cheap this maybe an option. The other problem with such a large lump on top of the piston is flame propogation. A smaller bump is much more preferable.
I bought a set of those TRW L2250's back in the late 70's real cheap because of the high compression. I milled off about .250" thou. and with a .035" gasket under 68-70cc heads I had a nice 10.5-11.0:1 compression ratio. Super grade fuel was still readily available then. The motor was a 327 + .030". I was using a Chevy "Pink" (LT1) grind solid lifter cam and from memory had about 160psi compression pressure with this combo. That motor is still seeing weekend use in a monaro cruising Adelaides streets to this day.
Depending on your cam selection you may be able to get away with a higher compression ratio but for a streeter about 10:1 is max these days.
Hope this helps.......Barry.
Hypereutectic pistons and turbos? Hal9000 Engine 18 02-23-2013 09:45 AM
trw forged 327 piston #L2211A 62CHEVYC10 Engine 8 07-06-2010 11:21 AM
327 Block Info GoneNova/406 Engine 5 04-07-2005 05:37 PM
? about dome piston's bowtieorbust Engine 5 09-19-2004 08:34 AM
327 rebuild help. SUGGESTIONS PLEASE DeezImpala Engine 1 06-24-2002 10:06 PM
