on older engine--should convert to PCV valve setup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2010, 07:33 PM
Besides spraying oil out of the breather pipe is there any advantage to converting to a PCV valve set-up?
Old 08-30-2010, 07:46 PM
yragat,
Not really. Some people say that the small amount of oil being mixed in with the air/fuel mixture lubes the upper cylinder walls. But if you have enough blow-by that oil is dripping onto the roadway then you may need more work than just a pcv up-grade.
Scholman(retired)
Old 08-30-2010, 07:50 PM
OLNOLAN's Avatar
maybe
Hey Man, On a near about stocker IMHO, No. When you start getting up in the HP, maybe the crankcase suction might help with ring seal and condensat
ion? Others may have opinions on this. olnolan
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Build up enough crankcase pressure, maybe flow oil past the front and rear mains? Prevent blowby past the rings? There are advantages.
Semper Fi
Old 08-30-2010, 09:15 PM
Originally Posted by scholman
yragat,
Scholman(retired)
LIKE WHAT?????
Old 08-30-2010, 10:26 PM
sqzbox's Avatar
My pipes are my music
Why?
To controll crankcase pressure and keep the engine from throwing oil and fumes out of the breather caps. On a high mileage worn out engine, it might keep the stink of blowby out of your nose!
Old 08-30-2010, 10:36 PM
SSedan64's Avatar
If it's blowing oil you may need one of these>> http://www.condensator.com/ or http://www.pbase.com/rsrock/oil_catch_can
Old 08-30-2010, 11:20 PM
yragat,
You wanted to know what might need to be fixed to stop the blow-by.
Rings could be worn. Cylinders could have a large amount of taper causing compression to be lost past the rings.
Bad valve guides on the exhaust valves allowing hot gasses to be pushed into the engine. All not good.
Have Fun
Scholman(retired)
Old 08-31-2010, 01:35 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
good link here
http://www.yourautonetwork.com/pcv_valve.html
Old 08-31-2010, 04:48 PM
sqzbox's Avatar
I acquired an old LeMans with a worn out 326 once. I liked the car with the 4 speed but it smoked something awful. Back in 74 Mobile oil had started selling it's Mobile 1 syn. oil and claimed a higher flash point being synthetic. So, I decided to experiment with it and at 5.00 a qt. (really high dollar back then)
I changed the oil and WALLA! no smoke. Only problem was it still used the same amount of oil at 5 bucks a qt. and it smelled like crap.
The cop's can cite you in California for excessive smoke but not for wasting money and grossing out everyone that follows you down the road.
Old 08-31-2010, 08:43 PM
Will I ever get it done?
Last journal entry: Hood
Do you mean the road draft tube? The one that exits the bottom of the car?
Run a compression test. If it comes out good, run a leak down test. If it comes out good, a PCV system will help you.
Here's why. All piston engines, no matter how well they are built, will have some blow-by past the rings. The blow-by collects in the crank case. At highway speeds, assuming it is not plugged up and you haven't altered the car in a way which will alter the air flow past the end of the road draft tube, the air passing over the end of the road draft tube will draw the blow-by out of the crankcase. Around town or idling, not so much. The blow-by will mix with moisture in the air and create acids in your oil. Results - sludge (or more frequent oil changes) and premature engine wear. A PCV system increases engine life because the "positive" in positive crankcase ventilation is just that; positive (and all the time).
If the engine fails a compression and/or leak down test, it probably doesn't matter.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Builder says 1/4 more on rockers....HHHMMM? sooper Engine 29 07-16-2010 02:17 PM
PCV valve, smoke out exhaust Biscuit6447 Engine 4 07-12-2009 06:30 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
