Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Older Howard cam
Old 11-02-2012, 08:12 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Set it up in a spare block with the crank, one rod and one piston in the #1 hole. Use a timing set to connect 'em and degree the cam with a degree wheel and pointer. A steel rule and feeler gauges will help you find TDC.
